Recommended Hardware for Testing 64 Ip @720p 30fps
Posted: Tue Mar 17, 2015 3:19 pm
Hi all.
Im new to this forum and is great to have a big commutity to handle any solution for this great piece of Software.
Im looking for some advice about using ZM for building a Test System that can handle 64Ch at 720p.
I understand that ZM needs a good and powerfull platform to manage this amount of Cameras.
The reason im looking for this solution is to replace a DAHUA NVS model SVR3016H wich has served very well at D1 Resolution. The only funtion it does is Recording the cameras directly to 4 groups of 4 HDD in Raid 5, for a total of 16 Disk. This is done for Backup of DAHUA NVRs.
The other thing about this is because this unit its only capable of Recording DAHUA Branded Cameras, NVRs or DVRs, so there is no way to configure Other ONVIF Compliant Cameras.
I really apreciate any advice, im able to test this as soon as you gave me some tips to start this test.
Here are the Computer Specs of DAHUA NVS SVR3016H for your concern:
1 x Intel Dual Core E5800 (Can be Upgraded to Quad Core XEON or Core 2 Quad)
1 x Supermicro X7SBE
2 x 2Gb kingston DDR2 ECC (4Gb Total)
2 x Marvell SATA/SAS Raid Controllers (PCIx 133mhz) (Dont Know the Brand or Chipset) (I need to investigate)
16 x Seagate Constellation 2Tb Drives
1 x Triple Redundant PSU
1 x RACk Enclosure with 16 HotSwap 3.5 Bays
I hope this request serves as a Start for building Hi-End ZM Devices.
Thaks in Advance.
Daniel
Thaks in Advance.
Daniel
