Page 1 of 1
NOT recording on SIGNAL for a remote camera
Posted: Fri Mar 20, 2015 10:35 pm
by asker
Hi, once or twice a day, I get an alarm event with an id of "SIGNAL". This is for remote cameras. On reviewing the frames, I notice that a couple of frames are all grey. I assume this means there was a temporary drop of Wi-Fi. How do I make sure ZM does _not_ record events with Signal loss? I only see an option to detect signal loss for local cameras, but I need it for remote cameras and not record.
Re: NOT recording on SIGNAL for a remote camera
Posted: Sat Mar 21, 2015 2:43 am
by kkrofft
Could you set the minimum # of alarm frames to 2 or three? If the bad images are only 1 frame a setting of 2 should skip them.
Posted: Sat Mar 21, 2015 3:17 am
by sime
Let them record and then use zmfilter to drp all event matchin singal?
I personally drop event with less than 4 alarm frames because of sunlights... Usually, signal event is only one frame and get ereased by this rules
