[SOLVED] Using control scripts from command line
sime
Post by sime »
Hi folks,
i use the DCS-5020L control script with zoneminder web interface...
I would need help to use them by command line...
I wanna use CRON to set On and OFF IR
the control code is :
sub wake
    my $self = shift;
    Debug( "Wake - IR on" );
    my $cmd = "setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=3&ConfigDayNightMode=Save";
    $self->sendCmd2( $cmd );
sub sleep
    my $self = shift;
    Debug( "Sleep - IR off" );
    my $cmd = "setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=2&ConfigDayNightMode=Save";
sub reset
    my $self = shift;
    Debug( "Reset - IR auto" );
    my $cmd = "setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=0&ConfigDayNightMode=Save";
I reied with wget http:user:pass@ip/setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=0&ConfigDayNightMode=Save
but id dont work...
any clues?
Simon
sime
Re: Using control scripts from command line (SOLVED)
Post by sime »
just found out that i need to use zmcontrol.pl --id X --command=wake
sorry for that
Simon
