I am running Ubuntu 12.04.5 LTS with zoneminder 1.25.0. Below are specs of the hardware I am running. About 20 times a day, and error will kick into the logs... " zms[30293]: ERR [Unable to send stream frame: Broken pipe] "
I think it is happening on random occasion when an event is triggered on that camera. It does not happen all the time, but just occasionally. I have seen it happen when trying to fix it, I walk out in front of the camera, and it triggers that error, and did not record the event in that case. I do not have a way of consistently proving that everytime it throws that error, though. Assuming it may not be recording when that happens, I would like to get to the root of the issue and fix it, so I do not miss an event. I am a little bit of a Linux novice, so more detail and commands help. Thanks!
This is from the ZM log window:
Date/Time Component PID Level Message File Line
2015-04-01 18:51:53.624060 zms 30106 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:51:34.321028 zms 30090 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:50:08.740366 zms 30063 ERR Unable to send stream frame: Broken pipe zm_monitor.cpp 3379
2015-04-01 18:50:03.566499 zms 30080 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:49:27.412490 zms 30078 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:48:40.430382 zms 30076 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:48:26.891035 zms 30074 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:48:17.887113 zms 30071 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:48:03.519279 zms 30069 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:47:40.616659 zms 30067 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 18:46:50.157003 zms 30065 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
2015-04-01 15:53:57.392686 zms 29661 ERR Unable to send stream frame: Broken pipe zm_monitor.cpp 3379
2015-04-01 15:48:25.812743 zms 29614 ERR Unable to send stream frame: Broken pipe zm_monitor.cpp 3379
2015-04-01 15:48:23.236114 zms 29637 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1275
Cameras = (4) Vivotek IP 8362
Running source type of FFMPEG and using RTSP at 1920x1080
Server info:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 12
On-line CPU(s) list: 0-11
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 62
Stepping: 4
CPU MHz: 3601.000
BogoMIPS: 7204.54
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 15360K
NUMA node0 CPU(s): 0-11
Memory
total used free shared buffers cached
Mem: 16372588 15884928 487660 0 289792 13237272
-/+ buffers/cache: 2357864 14014724
Swap: 4882428 218004 4664424
