zmrepo - CentOS 7.1
Posted: Thu Apr 02, 2015 6:50 pm
Hiya!!
CentOS 7.1 was released today and zmrepo keeps erroring out and its confused over the new version. Just wondering if somebody could fix this pleasee?
This is the errror:
--> Running transaction check
---> Package centos-release.x86_64 0:7-0.1406.el7.centos.2.6 will be updated
--> Processing Dependency: redhat-release = 7.0 for package: zmrepo-7-3.el7.centos.noarch
---> Package centos-release.x86_64 0:7-1.1503.el7.centos.2.8 will be an update
--> Finished Dependency Resolution
Error: Package: zmrepo-7-3.el7.centos.noarch (@/zmrepo-7-3.el7.centos.noarch)
Requires: redhat-release = 7.0
Removing: centos-release-7-0.1406.el7.centos.2.6.x86_64 (@updates)
Updated By: centos-release-7-1.1503.el7.centos.2.8.x86_64 (base)
redhat-release = 7.1
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root@noc yum.repos.d]
Thanks loads and happy Easter!
Chris
Chris
