Zoneminder on Lubuntu 14.04.02
Posted: Fri Apr 24, 2015 4:35 pm
I have installed zoneminder before and it works very well on ubuntu desktop 12 and ubuntu server 14.
I'm planning to use a old computer that uses Lubuntu, I followed the tutorial instalation at:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
The problem is that I can't see the stream images. I configure the cameras like I did before, and I just see the buttons play/pause etc...
I read your faq and I think I'm understanding the problem but I still need your help with that. So I attach the zm log if you can check and help me to fix that.
Thank you in advance.
