Problems with user authentication
philwild
Post by philwild »
Hi Zoneminder users.
I have a zoneminder configuration that appears to work perfectly when authentication is disabled. As soon as I activate user authentication (built-in) streaming/video playback stops working. I end up with a broken image icon where the stream should be
I am not using the cambozola plugin
I see the following in syslog
May 11 10:47:57 security zms[18636]: ERR [Unable to authenticate user]
May 11 10:47:57 security zms[18636]: INF [Terminating Logger]
May 11 10:47:58 security web_php[18152]: ERR [socket_sendto( /tmp/zm/zms-980916s.sock ) failed: No such file or directory]
If I turn authentication off, all works well and I do not see the above errors.
What might I be doing wrong?
Phil
Re: Problems with user authentication
Try turning your AUTH_RELAY setting to None.
bb
asker
Post by asker »
Hi, there are various things that could be happening. The key issue is that authentication failed, so ZMS does not stream.
Some initial things for you to respond to:
1. Which version of ZM and how did you install it? Package or source?
2. Please post the contents of /etc/zm/apache.conf
3. I assume you have configured a ZM user using its web interface and are able to log in successfully with it from the web interface?
For starters, please post your /etc/
philwild wrote:Hi Zoneminder users.
Phil
Please read before posting:
ES docs
zmNinja docs
philwild
Post by philwild »
bbunge wrote:Try turning your AUTH_RELAY setting to None.
bb
Thankyou. This resolved my problem =)
philwild
Post by philwild »
asker wrote:Hi, there are various things that could be happening. The key issue is that authentication failed, so ZMS does not stream.
The problem was resolved by disabling AUTH_RELAY. But to answer your questions
I'm using 1.28.1 on Ubuntu 14.04 installed from the ppa archive.
apache.conf in unadulterated from installation.
Yes, zm was configured from the web interface. Everything appears to work fine up until I turn authentication on.
Appreciate your response.
Cheers
Phil
asker
Post by asker »
No problem.
Bbunge - can you share some insight into what led you to suggest AUTH_RELAY as a problem? What does it do and what problem does it cause?
ES docs
zmNinja docs
It was something that worked for me some time back. Do not remember other than trying another setting when something does not work. Will set up a test machine and see f I can replicate the issue and come up with a reason. This may take me a couple of days due to some family commitments.
bb
Finally got time to set up a test machine. Was not able to replicate the problem. I just checked "OPT_USE_AUTH" after adding a new admin user. Was able to log in after saving the settings.
I remember changing "AUTH_RELAY" to None when I was trying to get ZM streams to show in a web page that did not require log in. With Hashed checked the streams would not always start.
bb
Changing AUTH_RELAY to none is a workaround, rather than a fix.
That simply turns off hash generation.
The following can cause the server to generate an incorrect hash:
- The server clock is more than 1 hour off
- The timezone in php.ini is not set at all or incorrectly
- AUTH_HASH_IPS is on, but the server cannot determine the IP of the remote client
Additionally, I am not entirely certain how tolerant the AUTH_HASH_SECRET is of extended ascii characters. If you are having trouble with auth hashing, then set the secret to something basic to verify that is not causing the problem.
