The upCam Cyclone HD is an new german webcam.
Does anyone know how i have to configure zonminder for the upCam Cyclone HD web cam.
upCam Cyclone HD a new german web cam
Re: upCam Cyclone HD a new german web cam
Answer from the upCam Support. I will try this:
Hallo,
danke für Ihre Anfrage, gerne helfe ich Ihnen weiter.
Die upCam Cyclone HD ist zwar noch nicht in der Liste von Zoneminder, allerdings können Sie die upCam Cyclone HD als "Generic" Kamera hinzu fügen und dafür die Snapshot- bzw. Videoadressen manuell eingeben:
Die Bild- und Videoadressen der upCam Cyclone HD sind folgende:
Der Snapshot lautet: http Adresse der Webcam /web/tmpfs/snap.jpg
H.264 Stream (HD): rtsp Adresse der Webcam /11
H.264 Stream (VGA): rtsp Adresse der Webcam /12
Bei weiteren Fragen helfe ich Ihnen gerne.
Hallo,
These are the basic settings:
Unter General:
Source Type: Ffmpeg
Maximum FPS: 10.00 …(In der Kamera habe ich 5 FPS eingestellt)
Alarm Maximum FPS: 10.00
Unter Source:
Source Path: rtsp://”user”:”password”@192.168.xxx.xxx:554/11 …(verwende den HD Stream)
Remote Method: RTP/RTSP
Target Colorspace: 24 bit color
Capture Width (pixels): 1600
Capture Height (pixels): 1200
Unter General:
Source Type: Ffmpeg
Unter Source:
Please help me. Now i need a control script for the upcam Cyclone HD to control pan, tilt and ir leds in Zoneminder.
Best regards puempel
If it does not exist, you will have to create one. It's not hard to create it as long as you know the 'commands' that this camera uses to pan/tilt/zoompuempel wrote:Please help me. Now i need a control script for the upcam Cyclone HD to control pan, tilt and ir leds in Zoneminder.
For example, here is a wiki entry I wrote on how I modified a script for my foscam camera. You can follow the same flow and create one for your camera. But first ask the support team of this camera for PTZ url/commands
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
