problems with both zm 9.14 and 9.15
johnmiles79
Post by johnmiles79 »
I gave up on 9.14 and decided to use 9.15 to upgrade my 9.12 install, I receive this message
# perl zmconfig.pl
Loading config from 'zmconfig.txt'
Loading config from DB
DBD::mysql::st execute failed: Table 'zm.Config' doesn't exist at zmconfig.pl line 1317.
Can't execute: Table 'zm.Config' doesn't exist at zmconfig.pl line 1317.
any ideas? thanks
zoneminder
Site Admin
Re: problems with both zm 9.14 and 9.15
Post by zoneminder »
Hi John,
Did you remember to run all the database upgrade scripts between .12 and .15?
Phil,
johnmiles79
just do something like this in the db directory where you untar'd your files:
say you are running zoneminder 0.9.11, then run the following to use zoneminder 0.9.15
mysql your_zoneminder_database < zmalter-0.9.12
mysql your_zoneminder_database < zmalter-0.9.13
johnmiles79
