BC-H08240A reports "Device or resource busy"
gerritkuehn
Post by gerritkuehn »
I'd like to use Zoneminder with the card mentioned above. I think I have the solo driver installed correctly, and I can get a digital stream displayed using, e.g., mplayer.
zmu gives me the following output:
Video Device: /dev/video0
General Capabilities
Driver: solo6x10
Card: Softlogic 6x10
Bus: PCI:0000:07:05.0
Version: 3.18.7
Type: 0x85200001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC-M
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
Formats:
UYUV 4:2:2 Packed (UYVY)
Crop Capabilities
Cropping is not supported
Inputs: 10
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Signal not detected (X)
Input 2
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 3
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 4
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 5
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 6
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 7
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Input 8
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Signal detected (X)
Input 9
Type: Camera
Audioset: 00000000
Standards: 0x10ff
Power on (X)
Signal detected (X)
So my signal on Input 0 is detected. However, when I run zoneminder via the webgui or " zmu -d /dev/video0 -q -v " on the commandline, I get this:
Jun 19 14:03:36 pt-video zmdc[3804]: INF ['zmc -d /dev/video0' starting at 15/06/19 14:03:36, pid = 4334]
Jun 19 14:03:36 pt-video zmdc[4334]: INF ['zmc -d /dev/video0' started at 15/06/19 14:03:36]
Jun 19 14:03:36 pt-video zmc_dvideo0[4334]: INF [No direct match for the selected palette and target colorspace. Format conversion is required, performance penalty expected]
Jun 19 14:03:36 pt-video zmc_dvideo0[4334]: INF [Starting Capture]
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x72900000-0x729a4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x00100000-0x001a4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x72a00000-0x72aa4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x00c00000-0x00ca4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x72b00000-0x72ba4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x00d00000-0x00da4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x71c00000-0x71ca4fff], got write-back
Jun 19 14:03:38 pt-video kernel: zmc:4334 map pfn RAM range req uncached-minus for [mem 0x00e00000-0x00ea4fff], got write-back
Jun 19 14:03:36 pt-video zmc_dvideo0[4334]: FAT [Failed to set video standard 255: Device or resource busy]
Jun 19 14:03:36 pt-video zmdc[3804]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
I don't know what causes this "Device or resource busy", and how to solve this. As stated above, mplayer works just fine with this device (and Google does not come up with any useful answer, either :-). So any hints would be greatly appreciated.
cu
Gerrit
