cannot start zoneminder
Hi
when i Start, the Zoneminder is stopped.
but when i create '/var/run/zm' at hand, Zoneminder is starting.
the error massage is Can't create missing temporary directory '/var/run/zm': Permission denied
What user must have more rights ?
Video data export is not working.
The massage is Command 'cat 'temp/zmFileList.txt' | zip -q 'temp/zmExport.zip' -@' returned with status 12
is it a right problem too ?
Re: cannot start zoneminder / Video export not working
had this error once... did you recently disable the zoneminder service from starting? in any case, all I did was reboot the server
- knight-of-ni
That means two things:
1) You don't have zoneminder installed correctly. When installed correctly that folder and the others it needs will get created automatically. We need to know what distro you are on and how you installed zoneminder to troubleshoot this.
2) you are trying to start zoneminder for the first time after boot up from the web console. Instead, you should configure zoneminder to start as a service, which gets us back to item 1. When starting as a service, zoneminder briefly has root privileges, which allows it to add any missing folders. This is not true if you try to start zoneminder from the web console.
Yes ist posible.
i have install it on Ubuntu lts with the Isaac Connor package.
i dont found a appliance with new Zoneminder so i tried this way.
i used this guide http://www.zoneminder.com/wiki/index.ph ... e_easy_way but install The Zoneminder 1.28
How can i fix it ?
With your Tip i found this guide to start Zoneminder as service ...
http://www.zoneminder.com/wiki/index.ph ... se_systemd
is this the right way ? (but www-data -> root)
Bernd
How can i fix it ?
Bernd
- knight-of-ni
We need to know exactly which version of Ubuntu you are using.
its Ubuntu 14.04.2 LTS GNU/Linux 3.16.0-43-generic x86_64
- knight-of-ni
Ubuntu 14.04 has the legacy Sys V Init, which means it does not have systemd.
You need to make sure you you init service file exists:
Then you start zoneminder from the command line by:
The zoneminder package from iconnor's ppa should configure your system to start zoneminder automatically at boot up, but just to be sure:
To verify zoneminder has started:
ls /etc/init.d/zoneminder
sudo service zoneminder start
sudo update-rc.d zoneminder defaults
sudo service zoneminder status
on sudo service zoneminder start i have an error :
/etc/init.d/zoneminder: 91: /etc/init.d/zoneminder: Syntax error: Unterminated quoted string
but there i dont found a cr
zmfix -a" sleep 15
#!/bin/sh
### BEGIN INIT INFO
# Provides: zoneminder
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Should-Start: mysql
# Should-Stop: mysql
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Control ZoneMinder as a Service
### END INIT INFO
# description: Control ZoneMinder as a Service
# chkconfig: 2345 20 20
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/bin"
RUNDIR=/var/run/zm
TMPDIR=/tmp/zm
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
mkdir -p $RUNDIR && chown www-data:www-data $RUNDIR
mkdir -p $TMPDIR && chown www-data:www-data $TMPDIR
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
echo
[ $RETVAL = 0 ] && touch /var/lock/zm
return $RETVAL
stop() {
echo -n "Stopping $prog: "
# Why is this status check being done?
# as $command stop returns 1 if zoneminder
# is stopped, which will result in
# this returning 1, which will stuff
# dpkg when it tries to stop zoneminder before
# uninstalling . . .
result=`$command status`
if [ ! "$result" = "running" ]; then
echo "Zoneminder already stopped"
echo
RETVAL=0
else
$command stop
RETVAL=$?
echo
[ $RETVAL = 0 ] && rm -f /var/lock/zm
fi
status() {
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart' | 'force-reload')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
- knight-of-ni
You made a typo when you tried to add "sleep 15".
Delete the first line. Then place the "sleep 15" statement under "start() {" per the instructions.
Thank you.
now zoneminder starts from console.
but it doesn't start automatically at boot.
I do not know if it is related but
Video Export makes an error
with *.tar there is no error, but the File is empty
Bernd
0 packages can be updated.
0 updates are security updates.
Last login: Mon Jul 13 13:12:12 2015 from 192.168.101.61
root@video:~# ls /etc/init.d/zoneminder
root@video:~# service zoneminder start
Starting ZoneMinder: success
root@video:~# update-rc.d zoneminder defaults
System start/stop links for /etc/init.d/zoneminder already exist.
root@video:~# service zoneminder status
root@video:~#
Bernd
Ok, it seems another Problem with Video Export, so i make a new Post with this new Problem.
