ZoneMinder was successfully installed on a PC running Ubuntu 14.04. A Linksys DCS5020L camera was successfully installed for standard viewing. This camera has PTZ capabilities, and the control script from the following link was identified:
http://www.zoneminder.com/wiki/index.ph ... rol_Script
The control script was copied using gedit into a new file DCS5020L.pm and saved at the following address:
usr/share/perl5/ZoneMinder/Control
The control script was recorded in the Control Panel per instructions provided at the following link: http://www.zoneminder.com/wiki/index.ph ... _DCS-5020L
The camera video is operational; however, efforts to use PTZ produce error reports similar to the following:
Control response was status = undefined
message = /usr/bin/zmcontrol.pl
-- panstep = 14
-- command = move Rel Right
-- id = 1 = >
I would appreicate your help resolving the problem. I am a Newbie to Linux and ZoneMinder; however, there seems to be a control conflict between the control scripts at zmcontrol.pl and the new DCS502L.pm
Thank you.
PTZ Linksys DCS5020L
- knight-of-ni
Re: PTZ Linksys DCS5020L
The search tool is your friend:
http://www.zoneminder.com/forums/viewto ... 280#p88280
The ptz script probably needs to be updated to be compatible with zoneminer 1.28.1.
The link describes the steps needed to accomplish that.
