Loss of image data issue
felixr
Post by felixr »
I have frequent losses of image data on all of the ip cameras connected to Zoneminder, looking like the image below:
http://fileshare.felnet.ro/042-capture.jpg
This is happening since I switched from version 1.25 to 1.28. It is not a network issue, as if I look at the same time at the web stream from the camera web interface and the image stream from Zoneminder, only the images in Zoneminder are affected. Looks like it is a software problem. Zoneminder has 6 ip wired cameras connected.
Any idea?
Re: Loss of image data issue
This is a known issue with ffmpeg.
Try using the search tool to find the many responses discussing torn, warped, corrupted, etc images with ffmpeg cams.
