Page 1 of 1
Installing 1.28.1 on Rapsberry Pi 2
Posted: Tue Aug 18, 2015 4:43 am
by Laurence243
Okay, so I have 1.25.0 running but after setting it up to send me emails via SSMTP and adding a filter for alert frames >= 1, it is still not sending me email notifications. I installed ZoneMinder via a guide I found that used this version, so I am thinking maybe updating it will solve my problem as there is a bug in the zmfilters.pl system that has been fixed since.
So I downloaded it from here
http://www.zoneminder.com/downloads, it downloaded as a tar.gz file.
I went to the Downloads folder and entered:
tar xvf ZoneMinder-1.28.1.tar.gz
this gave me a ZoneMinder-1.28.1 folder, I cd into this folder and try ./configure.......
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ ./configure
bash: ./configure: No such file or directory
okay...
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ make
make: *** No targets specified and no makefile found. Stop.
maybe this?
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ install
install: missing file operand
Try `install --help' for more information.
going to try this now then I guess...
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ sudo make install
make: *** No rule to make target 'install'. Stop.
I looked in the readme but it didn't say how to install the tar.gz version, only the .deb. What am I doing wrong?
Re: Installing 1.28.1 on Rapsberry Pi 2
Posted: Tue Aug 18, 2015 4:02 pm
by iconnor
Posted: Tue Aug 18, 2015 6:37 pm
by Laurence243
pi@raspberrypi ~ $ cd ./Downloads/
pi@raspberrypi ~/Downloads $ ls
pi@raspberrypi ~/Downloads $ tar zxf ./ZoneMinder-1.28.1.tar.gz
pi@raspberrypi ~/Downloads $ cd ./ZoneMinder-1.28.1/
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ libtoolize --force
bash: libtoolize: command not found
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ cd
pi@raspberrypi ~ $ sudo apt-get install build-essential
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi ~ $
Posted: Tue Aug 18, 2015 6:56 pm
by iconnor
apt-get install libtool
Posted: Tue Aug 18, 2015 7:20 pm
by Laurence243
Thank you, your help is greatly appreciated.
I've run into another roadblock though....
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ export LD_LIBRARY_PATH="/usr/local/lib:/opt/libjpeg-turbo/lib:$LD_LIBRARY_PATH"
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ DEB_HOST_GNU_TYPE=$(dpkg-architecture -qDEB_HOST_GNU_TYPE)
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ DEB_BUILD_GNU_TYPE=$(dpkg-architecture -qDEB_BUILD_GNU_TYPE)
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ CXXFLAGS=" -DZM_FFMPEG_CVS -DHAVE_LIBCRYPTO -msse2 -I/usr/local/include"
pi@raspberrypi ~/Downloads/ZoneMinder-1.28.1 $ CXXFLAGS="$CXXFLAGS" ./configure --with-libarch=lib/$DEB_HOST_GNU_TYPE --disable-debug \
> --host=$DEB_HOST_GNU_TYPE --build=$DEB_BUILD_GNU_TYPE --with-mysql=/usr \
> --with-webdir=/var/www/zm --with-ffmpeg=/usr --with-cgidir=/usr/lib/cgi-bin \
> --with-webuser=www-data --with-webgroup=www-data --enable-crashtrace=no \
> --enable-mmap=yes ZM_SSL_LIB=openssl ZM_DB_USER=zm ZM_DB_PASS=zm
configure: WARNING: unrecognized options: --enable-crashtrace
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking build system type... arm-unknown-linux-gnueabihf
checking host system type... arm-unknown-linux-gnueabihf
configure: WARNING: You can call configure with the --with-mariadb option.
This tells configure where to find the mariaDB C library and headers if configure cannot
locate them automatically.
e.g. --with-mariadb=/usr/local or --with-mariadb=/usr
configure: WARNING: You can call configure with the --with-polkit option.
This tells configure where to place the polkit policy files.
checking for arm-linux-gnueabihf-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for POLKIT... no
configure: error: Package requirements (polkit-gobject-1) were not met:
No package 'polkit-gobject-1' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables POLKIT_CFLAGS
and POLKIT_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Posted: Wed Aug 19, 2015 7:02 pm
by Laurence243
Any ideas? I followed the guide exactly but it doesn't work.
Posted: Thu Aug 20, 2015 5:57 am
by Laurence243
Ran and installed:
sudo apt-get install policykit-1
and
sudo apt-get install gobject-introspection
but I'm still getting the same error. Obviously I'm missing a package and I'm trying to figure it out for myself but I'm running out of ideas. That should have solved it, I would think ?
Posted: Thu Aug 20, 2015 10:50 am
by Laurence243
Installed polkit-kde-1 and am getting the same error still.
Posted: Thu Aug 20, 2015 1:30 pm
by knight-of-ni
From the command line:
sudo apt-get get install apt-file
sudo apt-file update
apt-file search polkit-gobject
Here are the results on my particular system:
abi-compliance-checker: /usr/share/abi-compliance-checker/modules/Targets/unix/descriptors/libpolkit-gobject.xml
libpolkit-gobject-1-0: /usr/lib/x86_64-linux-gnu/libpolkit-gobject-1.so.0
libpolkit-gobject-1-0: /usr/lib/x86_64-linux-gnu/libpolkit-gobject-1.so.0.0.0
libpolkit-gobject-1-0: /usr/share/doc/libpolkit-gobject-1-0/changelog.Debian.gz
libpolkit-gobject-1-0: /usr/share/doc/libpolkit-gobject-1-0/copyright
libpolkit-gobject-1-dev: /usr/lib/x86_64-linux-gnu/libpolkit-gobject-1.a
libpolkit-gobject-1-dev: /usr/lib/x86_64-linux-gnu/libpolkit-gobject-1.so
libpolkit-gobject-1-dev: /usr/share/doc/libpolkit-gobject-1-dev/changelog.Debian.gz
libpolkit-gobject-1-dev: /usr/share/doc/libpolkit-gobject-1-dev/copyright
These results tell me the exact name of the package I need to install for my distro (Ubuntu). You should follow the same steps for your distro to verify the package name is the same.
Why are you are trying to build from source when 1.28.x packages are available for the pi?? You are dong this the hard way.
ZoneMinder is not easy to build because of all its dependencies, even for those accustomed to building from source.
Posted: Thu Aug 20, 2015 7:06 pm
by Laurence243
When I do sudo apt-get install zoneminder I get version 1.25.0 which doesn't send me email alerts, I think due to a bug in zmfilters.pl.
Posted: Thu Aug 20, 2015 7:15 pm
by knight-of-ni
You should search this forum for the other raspberry pi threads.
There you will find information on how to install the latest zoneminder packages for your raspberry pi.
Posted: Fri Aug 21, 2015 5:11 am
by Laurence243
Here is the output, not sure what to do with it though ?
libpolkit-gobject-1-0: /usr/lib/arm-linux-gnueabihf/libpolkit-gobject-1.so.0
libpolkit-gobject-1-0: /usr/lib/arm-linux-gnueabihf/libpolkit-gobject-1.so.0.0.0
libpolkit-gobject-1-dev: /usr/lib/arm-linux-gnueabihf/libpolkit-gobject-1.a
libpolkit-gobject-1-dev: /usr/lib/arm-linux-gnueabihf/libpolkit-gobject-1.so
libpolkit-gobject-1-dev: /usr/lib/arm-linux-gnueabihf/pkgconfig/polkit-gobject-1.pc
And I'll do some searching on here. I added iconnor's PPA to my sources list but it always times out when I do apt-get update
added to /etc/apt/sources.list
deb <removed because forum>/debian wheezy/
The forum won't let me post URLs so I can't link you the page I got the source from but it is github's Packages page for ZoneMinder, copy and pasted the deb line for wheezy into /etc/apt/sources.list
W: Failed to fetch <removed because forum>/iconnor/zoneminder/ubuntu/dists/wheezy/main/source/Sources 404 Not Found
W: Failed to fetch <removed because forum>/iconnor/zoneminder/ubuntu/dists/wheezy/main/binary-armhf/Packages 404 Not Found
Posted: Sun Aug 23, 2015 8:56 am
by Laurence243
Any idea why iconnor's setup 404's?
Posted: Sun Aug 23, 2015 9:28 am
by marco123
Posted: Sat Aug 29, 2015 5:43 am
by Laurence243
That link doesn't even have the deb extension to add to the sources list.
I have it added properly but it 404's at iconnor's repository. Why?
