mocord not quite what I want
mikeybs
Post by mikeybs »
I would like to create a setup where my monitor keeps a full 24 hours worth of recorded footage, and also creates separate events for motion detection exactly like the events that are generated when only motion detection is enabled. With mocord I can see how many alarm frames are in a given 10 minute event of recording, but I have to manually go through the event to find the motion segments. I would like a separate event created for motion events that only shows what is captured during the motion alarm.
Re: mocord not quite what I want
Did you try Timeline?
Click on the events for the Day, then click on Show Timeline.
