help, add as an external monitor DVR in my ZM 1.28
aodiaz
Post by aodiaz »
Hello everyone !, see !, I installed a 1.28 ZM !, which works great now, I wanted to add a DVR of 8 cameras (digital recorder 8 cameras), the DVR is Chinese and is installed in another physical place which it is accessible via internet explorer or cell smoothly !, he wanted to add DVR and monitor cameras as my ZM, it is possible ??, any help please, I thank you !, if you need additional information, call me.
l80jas
Re: help, add as an external monitor DVR in my ZM 1.28
Post by l80jas »
Hi there.
What kind of DVR are you trying to connect to?
If it supports rtsp you should be able to connect to the streams if you port forward port 554 on your router with ffmpeg or the remote option. I have had better results with ffmpeg and Centos rather than the remote method.
If you can also try with vlc player that will give you a good starting point.
Best of luck.
