One Camera Stops Showing Image Ever So Often
tyler_h
Post by tyler_h »
Maybe once or twice a month my main Camera will stop showing any video, if i reset the server, the camera comes back to life. This is the Error log file..
I would obvious like to over come this issue or at the very least get an email when the camera isnt showing any new frames.
Comments, suggestions?
Date/Time
Component PID Level Message File Line
2015-09-06 08:24:06.636999 web_php 17758 ERR socket_sendto( /var/run/zm/zms-341138s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-09-06 08:23:56.114091 zms 1649 ERR Terminating, last frame sent time 1441549435.613954 secs more than maximum of 10.000000 zm_monitor.cpp 4155
2015-09-05 20:44:27.587120 zmdc 18158 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2015-09-05 09:07:52.053363 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-04 19:44:26.999450 zmdc 18158 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2015-09-03 18:44:26.285460 zmdc 18158 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2015-09-03 17:39:00.581540 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-02 17:44:25.574750 zmdc 18158 ERR 'zmupdate.pl -c' exited abnormally, exit status 9 zmdc.pl
2015-09-02 06:54:14.344448 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 21:19:30.112132 web_php 17989 ERR socket_sendto( /var/run/zm/zms-830100s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-09-01 21:19:19.326451 zms 25821 ERR Terminating, last frame sent time 10.185099 secs more than maximum of 10.000000 zm_monitor.cpp 4155
2015-09-01 19:51:26.496071 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:50:50.712732 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 999
2015-09-01 19:41:53.125650 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:41:08.411785 zmc_m3 19929 ERR Connection dropped by remote end zm_remote_camera_http.cpp 645
2015-09-01 19:40:46.987693 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:27:21.244941 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 645
2015-09-01 19:27:16.608264 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:26:57.897743 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:26:25.483348 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 999
2015-09-01 19:26:14.533979 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:24:26.384483 zmc_m3 19669 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
2015-09-01 19:21:37.167020 zmdc 18158 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2015-09-01 19:21:37.146994 zmc_m3 19662 ERR Failed to pre-capture monitor 3 (0/1) zmc.cpp 260
2015-09-01 19:21:37.142181 zmc_m3 19662 ERR Unable to connect to camera zm_remote_camera_http.cpp 1148
2015-09-01 19:21:37.137428 zmc_m3 19662 ERR Unable to connect to the remote camera, aborting zm_remote_camera_http.cpp 115
2015-09-01 19:21:29.158680 zmdc 18158 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2015-09-01 19:21:29.133467 zmc_m3 19656 ERR Failed to pre-capture monitor 3 (0/1) zmc.cpp 260
2015-09-01 19:21:29.129227 zmc_m3 19656 ERR Unable to connect to camera zm_remote_camera_http.cpp 1148
2015-09-01 19:21:29.125000 zmc_m3 19656 ERR Unable to connect to the remote camera, aborting zm_remote_camera_http.cpp 115
2015-09-01 19:20:45.488309 zmc_m3 2361 ERR Connection dropped by remote end zm_remote_camera_http.cpp 999
2015-09-01 19:14:29.924345 zmc_m3 2361 ERR Connection dropped by remote end zm_remote_camera_http.cpp 1048
mikb
Re: One Camera Stops Showing Image Ever So Often
Post by mikb »
Take the hint, your camera doesn't want to talk to you :)
You might get more useful replies if you add some more info ...
What camera is it?
How is the camera connected (wired, wireless?)
Do you have other cameras that are affected/not?
When ZM won't talk to the camera, can you still reach it from the server (in a web browser, etc.)
What's the spec of the server (memory, etc) -- are you running out of resources? What else is the server doing?
I've had something like this -- resetting the server was no use. It was the camera that was broken -- constantly streaming video and images eventually tickled a memory leak in the camera, which would then just drop the connection, repeatedly. Rebooting the camera once a week, automated, solved my problem. You say that you need to reboot the SERVER? Makes me wonder if that's fixing, or masking the problem :)
tyler_h
Post by tyler_h »
What camera is it
https://www.aartech.ca/hdbw4300en-0280b ... dahua.html
Wired, POE
One other Foscam, not affected that is wireless
Yes,
Quad core 1.7Ghz with 8gb Ram, it does nothing other then zoneminder and collect dust, sometimes plex.
I believe it is the camera that causes the problem, but zoneminder wont pick it back up when it works again. I have a Vera 3 ZWave controller that picks up the JPEG stream of the camera and when I noticed when I try to view the camera in the vera software, it drops out of zoneminder until I reset the zoneminder server, not the PC itself. I do hate this camera but am wondering why zoneminder wont pick it back up when it comes online.
