Restart Zoneminder Automatically
jeepnjeff
Post by jeepnjeff »
The issue is after about a day ZM will start losing camera connectivity on one or more of my 6 cameras. Simply restarting ZM from the console will get all the cameras working again. I was wondering if there is a way for ZM to restart it itself at a designated time automatically thru some sort of filter or option setting. Any solutions please help.
Re: Restart Zoneminder Automatically
Set up a CRON job to change the run state of ZM. Should be documented in the WIKI.
By any chance are your cameras that are stopping running libvlc?
jeepnjeff
Post by jeepnjeff »
Yes, all my cameras are running on libvlc.
Switch to ffmpeg and your cameras will stay up.
jeepnjeff
Post by jeepnjeff »
I've found something similar in wiki that has different modes for certain time of day I have saved a 12am restart in the console.
What would a cron tab look like to restart ZM? and what file would I modify to enter the new tab line?
meon
Post by meon »
Here you can generate a cron job for a command as e.g. "sudo service zoneminder restart"
generateit[dot]net [ slash ] cron-job (sorry, can't post links)
Then you need to add the line to your crontab, after you have entered your wished dates into the site it shows you what to do.
  • Mini-ITX Fractal Nas Array
  • i7-3770K + 12GB DDR3
  • 6x Samsung HD204UI Raid5/Raid6
  • Ubuntu 14.04 Minimal Server
    * Archipel Orchestrator Virtualization Host
    * Xubuntu Desktop with Plank Dock
[/color]
jeepnjeff
Post by jeepnjeff »
Got figured out thanks so much for help. First time setting up cron jobs. Learned a lot. :D
bomberb17
Post by bomberb17 »
For some reason, my zoneminder goes into the stop state at random times.
I want to setup a cron job for checking if it's running, and if not restart it.
I know how to start it by invoking /usr/bin/zmpkg.pl xxx (where xxx=state)
but how can I check if it's running?
mikb
Post by mikb »
root@perkin:~# zmpkg.pl status
running
should do it ...
Or ... just
root@perkin:~# zmpkg.pl start
periodically anyway -- if it's already running, it comes back quickly without doing anything.
Of course none of this is the root cause of why your Zoneminder is stopping itself, you may wish to hunt that down. Check the zoneminder logs to see if you can see why, next time it comes up as "stopped". The last entries in the log may give a clue as to why it all stopped.
bomberb17
Post by bomberb17 »
Ok here are the last lines of the log after it has stopped (for no apparent reason..)
Jul  1 16:03:15 odroid-server zmc_dvideo2[29671]: WAR [Buffer overrun at index 143, image 131643, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:03:16 odroid-server zmc_dvideo2[29671]: WAR [Buffer overrun at index 164, image 131664, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:03:17 odroid-server zmc_dvideo2[29671]: WAR [Buffer overrun at index 205, image 131705, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:03:18 odroid-server zma_m3[29809]: INF [Eisodos: 125937 - Gone into alert state]
Jul  1 16:03:18 odroid-server zmc_dvideo2[29671]: WAR [Buffer overrun at index 226, image 131726, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:03:41 odroid-server zma_m3[29809]: INF [Eisodos: 126000 - Analysing at 3.39 fps]
Jul  1 16:03:41 odroid-server rsyslogd-2007: action 'action 9' suspended, next retry is Fri Jul  1 16:05:11 2016 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul  1 16:03:45 odroid-server zma_m3[29809]: INF [Eisodos: 126012 - Left alarm state (952) - 171(46) images]
Jul  1 16:03:46 odroid-server zma_m3[29809]: INF [Eisodos: 126012 - Closing event 952, alarm end]
Jul  1 16:03:47 odroid-server zma_m3[29809]: INF [Eisodos: 126035 - Gone into prealarm state]
Jul  1 16:03:47 odroid-server zma_m3[29809]: INF [Eisodos: 126042 - Gone into prealarm state]
Jul  1 16:04:19 odroid-server zma_m3[29809]: INF [Eisodos: 126193 - Gone into prealarm state]
Jul  1 16:04:24 odroid-server zmc_dvideo1[29653]: INF [Saloni: 130000 - Capturing at 4.00 fps]
Jul  1 16:04:28 odroid-server zmc_dvideo2[29671]: INF [Eisodos: 132000 - Capturing at 10.31 fps]
Jul  1 16:04:32 odroid-server zma_m2[29710]: INF [Saloni: 129948 - Gone into prealarm state]
Jul  1 16:04:33 odroid-server zma_m2[29710]: INF [Saloni: 129950 - Gone into alarm state]
Jul  1 16:04:33 odroid-server zma_m2[29710]: INF [Saloni: 129950 - Opening new event 953, alarm start]
Jul  1 16:04:42 odroid-server zmc_dvideo1[29653]: WAR [Buffer overrun at index 36, image 130286, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:04:44 odroid-server zma_m3[29809]: INF [Eisodos: 126284 - Gone into prealarm state]
Jul  1 16:04:44 odroid-server zmc_dvideo1[29653]: WAR [Buffer overrun at index 51, image 130301, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:04:46 odroid-server zma_m2[29710]: INF [Saloni: 129954 - Gone into alert state]
Jul  1 16:05:03 odroid-server zma_m3[29809]: INF [Eisodos: 126365 - Gone into prealarm state]
Jul  1 16:05:04 odroid-server zma_m2[29710]: INF [Saloni: 130000 - Analysing at 3.66 fps]
Jul  1 16:05:14 odroid-server zma_m2[29710]: INF [Saloni: 130029 - Left alarm state (953) - 131(6) images]
Jul  1 16:05:14 odroid-server rsyslogd-2007: action 'action 9' suspended, next retry is Fri Jul  1 16:06:44 2016 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul  1 16:05:15 odroid-server zma_m2[29710]: INF [Saloni: 130029 - Closing event 953, alarm end]
Jul  1 16:05:30 odroid-server zma_m3[29809]: INF [Eisodos: 126474 - Gone into prealarm state]
Jul  1 16:05:51 odroid-server zma_m3[29809]: INF [Eisodos: 126555 - Gone into prealarm state]
Jul  1 16:05:57 odroid-server zma_m2[29710]: INF [Saloni: 130220 - Gone into prealarm state]
Jul  1 16:05:58 odroid-server zma_m2[29710]: INF [Saloni: 130222 - Gone into alarm state]
Jul  1 16:06:00 odroid-server zma_m2[29710]: INF [Saloni: 130222 - Opening new event 954, alarm start]
Jul  1 16:06:03 odroid-server zmwatch[29712]: INF [Analysis daemon for  Saloni needs restarting, time since last analysis 6 seconds (1467378363-1467378357)]
Jul  1 16:06:05 odroid-server zmwatch[29712]: INF [Restarting analysis daemon for  Saloni]
Jul  1 16:06:05 odroid-server zma_m3[29809]: INF [Eisodos: 126606 - Gone into prealarm state]
Jul  1 16:06:07 odroid-server zmc_dvideo1[29653]: WAR [Buffer overrun at index 147, image 130897, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:06:10 odroid-server zmdc[29565]: INF ['zma -m 2' sending stop to pid 29710 at 16/07/01 16:06:10]
Jul  1 16:06:12 odroid-server zmc_dvideo1[29653]: INF [Saloni: 131000 - Capturing at 9.17 fps]
Jul  1 16:06:14 odroid-server zma_m2[29710]: INF [Got signal 15 (Terminated), exiting]
Jul  1 16:06:15 odroid-server zma_m2[29710]: INF [Saloni: 130225 - Closing event 954, shutting down]
Jul  1 16:06:16 odroid-server zma_m3[29809]: INF [Eisodos: 126657 - Gone into prealarm state]
Jul  1 16:06:17 odroid-server zmc_dvideo1[29653]: WAR [Buffer overrun at index 152, image 131152, slow down capture, speed up analysis or increase ring buffer size]
Jul  1 16:06:18 odroid-server zmdc[29565]: WAR ['zma -m 2' has not stopped at 16/07/01 16:06:18. Sending KILL to pid 29710]
Jul  1 16:06:19 odroid-server zmdc[29565]: INF ['zma -m 2' exited normally]
Jul  1 16:06:19 odroid-server systemd[1]: zoneminder.service: Main process exited, code=exited, status=4/NOPERMISSION
Jul  1 16:06:19 odroid-server zmpkg[31439]: INF [Sanity checking States table...]
Jul  1 16:06:20 odroid-server zmpkg[31439]: INF [Command: stop]
Jul  1 16:06:21 odroid-server zma_m3[29809]: INF [Eisodos: 126673 - Gone into prealarm state]
Jul  1 16:06:23 odroid-server systemd[1]: zoneminder.service: Control process exited, code=exited status=1
Jul  1 16:06:24 odroid-server zmc_dvideo1[29653]: INF [Got signal 15 (Terminated), exiting]
Jul  1 16:06:25 odroid-server zmc_dvideo2[29671]: INF [Got signal 15 (Terminated), exiting]
Jul  1 16:06:25 odroid-server zma_m3[29809]: INF [Got signal 15 (Terminated), exiting]
Jul  1 16:06:25 odroid-server systemd[1]: zoneminder.service: Unit entered failed state.
Jul  1 16:06:25 odroid-server systemd[1]: zoneminder.service: Failed with result 'exit-code'.
