Page 1 of 1
Same Image On All Cameras
Posted: Mon Sep 28, 2015 7:49 pm
by oakguy
Team,
I have a older Geovision GV600 card and have the same image on all four monitors. So the card is working. I have tried the various fixes to no success. NTSC and I tried several Capture Palette settings. Any ideas? Unbuntu Server 14.04.3 LTS.
Oakguy
[ 15.094656] bttv: driver version 0.9.19 loaded
[ 15.094659] bttv: using 32 buffers with 2080k (520 pages) each for capture
[ 15.094844] bttv: Bt8xx card found (0)
[ 15.094980] bttv: 0: Bt878 (rev 17) at 0000:04:05.0, irq: 17, latency: 32, mmio: 0xfbffe000
[ 15.099101] bttv: 0: subsystem: 6f17:4765 (UNKNOWN)
[ 15.099105] bttv: 0: using: Geovision GV-800(S) (master) [card=157,insmod option]
[ 15.121357] bttv: 0: tuner absent
[ 15.121359] bttv: 0: the autoload option is obsolete
[ 15.121360] bttv: 0: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 15.121410] bttv: 0: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 15.160747] bttv: PLL set ok
[ 15.160991] bttv: 0: registered device video0
[ 15.161125] bttv: 0: registered device vbi0
[ 38.423699] bttv: 0: PLL can sleep, using XTAL (28636363)
Re: Same Image On All Cameras
Posted: Tue Sep 29, 2015 5:03 pm
by oakguy
I discovered that I had the wrong card setting in bttv.conf. This is resolved.
