Analysis Images Not Being Saved
red-dog
Post by red-dog »
I can't seem to get ZM to save the analysis images. This used to work and I think it broke when I updated from 1.28.0 to 1.28.1, but going back to 1.28.0 doesn't fix the problem.
My events folder only has xxx-capture.jpg files and doesn't have any xxx-analyse.jpg files.
CREATE_ANALYSIS_IMAGES is enabled and I can't find anything in the logs indicating a problem.
I'm running Centos 6.7.
Anyone have any suggestions?
red-dog
Re: Analysis Images Not Being Saved
Post by red-dog »
For what it's worth, I've narrowed the problem down to the Alarm Check Method. Analysis images are not created if the Alarm Check Method is set to AlarmedPixels or FilteredPixels. They are only created when Alarm Check Method is set to Blobs. I don't think this limitation existed in previous versions.
