Page 1 of 1
ZM 1.28.107 for Ubuntu now in PPA
Posted: Wed Oct 14, 2015 11:36 pm
by bbunge
The iconnor PPA has been updated with ZM 1.28.107 for Ubuntu 14.04 and 15.04.
EDIT 16OCT15
Update procedure for 14.04:
http://www.zoneminder.com/wiki/index.ph ... PA_version
Update procedure for 15.04:
http://www.zoneminder.com/wiki/index.ph ... o_1.28.107
Re: ZM 1.28.107 for Ubuntu now in PPA
Posted: Thu Oct 15, 2015 12:34 am
by bbunge
Upgrade worked but...
I had to edit the php.ini and set the timezone
and
I had to access the GUI using ip-address/zm/www I know this is likely a simple change but I can't put my finger on it at this time. Stay tuned!
Posted: Thu Oct 15, 2015 12:38 am
by bbunge
Edit..
Well, it was not as simple as I had hoped. I was able to get my server running but have to put the changes together so someone else can understand them. Might be sometime Thursday before I get to them.
bb
Posted: Thu Oct 15, 2015 1:03 pm
by bbunge
Install procedure for Ubuntu 14.04 with ZM 1.28.107 has been updated:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Posted: Thu Oct 15, 2015 8:12 pm
by pete_c
Initially when I updated did also lose the GUI access such that I could only get to the gui as above. I ended up deleting Zoneminder and reinstalling it before I read the upgrade text. I did lose my DB and all my monitors.
It only took a few minutes to get it going again.
That said there is an issue with the zone image for configuring motion.
I do not see the zone image right now such that I cannot configure image motion detection.
I have written to Isaac about the issue. Is there another place to post relating to this build?
Posted: Thu Oct 15, 2015 8:20 pm
by bbunge
Install procedure for Ubuntu 15.04 with ZM 1.28.107 has been updated
Posted: Thu Oct 15, 2015 8:41 pm
by bbunge
I have prepared an upgrade instruction from my experiences of last night. I've done this from memory and sketchey notes so it may not be perfect. Will drop back to ZM 1.26.5 and run this to validate it.
See original post...
