Installing on Ubuntu 14.04 -- SQL-ERR dbFetchOne no result
eatkeylimepie
Post by eatkeylimepie »
Hi All,
I followed the directions at http://www.zoneminder.com/wiki/index.ph ... e_easy_way
After completing the process and visiting localhost/zm the following error is present:
SQL-ERR dbFetchOne no result, statement was 'select Name from States where IsActive = 1'
Any help would be appreciated.
Re: Installing on Ubuntu 14.04 -- SQL-ERR dbFetchOne no resu
That procedure s obsolete. Use the one for 1.28.107
eatkeylimepie
Cool thanks for the tip, I sought out instructions for 1.28.107 and found the database setup steps, all is well now.
