Page 1 of 1
{SOLVED} HOOTOO PTZ HD and HOSAFE 1MB1W HD IP Cam and ZM
Posted: Mon Oct 19, 2015 7:02 pm
by West Slope
Hi all,
To start out. I have never done anything like this before and have a lot of problems. Over the weekend I set ZM up on my laptop from:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
I have a friend that has no problems at all, same HOSAFE 1MB1W HD IP Camera and I've set mine up like he did.
"source type ffmpeg using source path rtsp://user:password@hostname:port and remote method RTP/RTSP".
Not, so with me. The cam I'm using is a HOSAFE 1MB1W HD IP Camera. I don't see the cam in the supported cams. With all that is happening, it has just about brought my laptop to almoast a complete stand still. I get errors like:
2015-10-19 11:20:31.805508 zmc_m1 6324 ERR Unable to open input rtsp://admin@192.168.1.11:9101 due to: Connection reset by peer zm_ffmpeg_camera.cpp 270
2015-10-19 11:21:22.215452 zms 6357 WAR Exceeded temporary buffer, resuming live play zm_monitor.cpp 4379
2015-10-19 07:50:06.411019 web_js 3120 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-246863w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
I do have a password from HOSAFE for the cam and I see no place to insert it. Might that be the problem with this "the Connection reset by peer"? All I get is a blue window viewing the cam and I see that there's a lot of other people with the same problem. In short. I'm asking how do I get ZM running right?
Re: HOSAFE 1MB1W HD IP Camera and ZM
Posted: Tue Oct 20, 2015 6:39 am
by PacoLM
Maybe you missed the password in the source path, try with:
rtsp://admin:YOURPASSWORD@192.168.1.11:9101
Hope it helps,
PacoLM
Posted: Tue Oct 20, 2015 10:12 pm
by West Slope
Thanks PacoLM,
I just got a HOOTOO PTZ. Same there too and I added the password.
2015-10-20 15:34:52.342963 zmc_m2 4402 ERR Unable to open input rtsp://admin:admin@192.168.1.12:254 due to: Operation now in progress zm_ffmpeg_camera.cpp
The port is 254, but the same crap. If I could only have said what I really wanted too. 254 is what it's shows with Windows. I guess it can be done and once I figure it out, it will be head banging time.
Thanks again
Posted: Tue Oct 20, 2015 11:47 pm
by aaronl
I used this tool to figure out the exact URL of my cameras:
http://sourceforge.net/projects/onvifdm/
It made it a lot easier.
Aaron
Posted: Wed Oct 21, 2015 12:14 am
by West Slope
Hi Aaron,
I just downloaded it and will let you know how it turns out.
Thanks!
Posted: Wed Oct 21, 2015 1:52 am
by West Slope
That did it Aaron. YEeeHAaaa :lol:
rtsp://admin:admin@192.168.1.12:554/11
After a week of trying to figure it out. The software for the cam didn't show that IP. Now I might find the IP for my other cam.
Thank you, so much!
P.S. Just nailed my HOSAFE. That app is great.
Re: {SOLVED} HOOTOO PTZ HD and HOSAFE 1MB1W HD IP Cam and ZM
Posted: Thu Sep 15, 2016 6:02 pm
by dlaw
This worked for me in Zoneminder v1.30 with a Hosafe 1MD1W:
On the "Source" tab for the camera:
Remote Protocol: RTSP
Remote Method: RTP/Unicast
Remote Host Name 10.x.x.x (substitute your IP address as a dotted quad)
Remote Host Port 554
Remote Host Path user=admin
Target Colorspace: 24 bit color
Capture Width 1280
Capture Height 720
