How To Disable Coloration Of Blobs
sgharp
Post by sgharp »
I'm using v1.28.107. When I define a new zone, the default "Alarm Color" is red (255/0/0). This causes some of the JPG images saved during an alert to have a squiggly red outline around the blob area during and event.
How can I disable this "feature"? I need to have clean, clear images stored in case they're needed for prosecution. Should I use AlarmedPixels or FilteredPixels instead of Blobs or will setting Alarm Color to 0/0/0 do the trick? Is there a better way to continue using Blobs but not have the red squiggle on my images?
Thanks....
Re: How To Disable Coloration Of Blobs
Those images are the alarmed analysis mages.
Uncheck CREATE_ANALYSIS_IMAGES
bb
