TypeError from logs 1.28.1 ubuntu 15.10 x64
ccjames9
Post by ccjames9 »
I am running ubuntu 15.10 x64 with ZM 1.28.1
Looked into my logs and found theses messages
Date/Time
Component PID Level Message File Line
2015-10-26 18:15:25.607061 web_js 5526 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:19.064835 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:18.926082 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:18.785481 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:17.464982 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 21:05:39.600564 zms 1790 ERR Unable to send raw frame 95: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 21:05:23.399976 zms 1790 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:27.380748 zms 1774 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:23.985466 zms 1769 ERR Unable to send raw frame 69: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 21:04:18.489401 zms 1770 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:09.418709 zms 1769 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:03:58.144219 zms 1768 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 20:08:22.858043 zms 1616 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 20:08:21.383128 zms 1615 ERR Unable to send raw frame 53: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 20:08:13.463949 zms 1615 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
What do theses errors mean?
Capturing 1 input BNC swann pro 690 ptz dome camera, 2x Foscam HD Wireless IP Cameras
Re: TypeError from logs 1.28.1 ubuntu 15.10 x64
What type of cameras are you running?
How much memory does your system have?
Do these errors show up only when you run Montage view?
bb
ccjames9
Post by ccjames9 »
bbunge wrote:What type of cameras are you running?
I am running an dit 4 bt878 capture card http://digi-it.co.kr/product/sub1.htm with 4 inputs but only using one input to my swann cam, No PTZ yet but ordered a PTZ serial port.
/etc/modprobe.d/bbtv.conf
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0
only CH4 on the card is working reset are blue (what is fine for my setup)
bbunge wrote:How much memory does your system have?
2gb ddr2 667mhz and also a intel dual core 2.80ghz (this is any help?)
bbunge wrote:Do these errors show up only when you run Montage view??
Dont think i have ever used it yet. Only click on Outside (name of my cam feed)
I cant give us the full logs as i have turned the system off overnight.
Date/Time
2015-10-27 12:44:26.540580 zms 1909 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:20.101540 zms 1908 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:15.198171 zms 1907 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:12.157910 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:43:49.406943 zms 1872 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:43:46.016980 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:43:13.371037 zms 1837 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:43:10.536910 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:59.526186 zms 1802 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:54.782240 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:42.579091 zms 1766 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:39.141540 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:27.194917 zms 1732 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:22.847194 zms 1731 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:17.622572 zms 1730 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:41:55.959527 zms 1729 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:41:44.170009 zms 1726 ERR Unable to send raw frame 183: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 12:41:23.332773 zms 1726 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:12:59.548140 zms 1553 ERR Unable to authenticate user /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zms.cpp 225
2015-10-27 11:03:16.347006 zms 1492 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:30.500319 zms 1458 ERR Unable to send raw frame 61: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 11:00:15.625564 zms 1458 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:15.601749 zms 1454 ERR Unable to send raw frame 61: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 11:00:13.100753 zms 1457 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:11.846850 zms 1455 ERR Unable to send stream frame: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1332
2015-10-27 11:00:07.191255 zms 1455 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:56.827984 zms 1454 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:43.473822 zms 1451 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:42.530708 zms 1450 ERR Unable to send raw frame 41: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:59:40.461516 zms 1450 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:50:20.893712 zms 1426 ERR Unable to send raw frame 84: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:50:09.856620 zms 1423 ERR Unable to send raw frame 69: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:50:05.033351 zms 1426 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:49:55.313374 zms 1423 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:49:36.631124 zms 1421 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:41:10.012610 zms 1395 ERR Unable to authenticate user /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zms.cpp 225
2015-10-27 10:32:22.980376 zms 1253 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:31:42.650510 zmdc 1150 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:42.593805 zma_m6 1225 ERR Shared data not initialised by capture daemon for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 421
2015-10-27 10:31:42.478270 zmdc 1150 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:42.390980 zmdc 1150 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:41.881839 zma_m6 1201 ERR Got empty memory map file size 0, is the zmc process for this monitor running? /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 513
