Page 1 of 1
TypeError from logs 1.28.1 ubuntu 15.10 x64
Posted: Mon Oct 26, 2015 6:25 pm
by ccjames9
I am running ubuntu 15.10 x64 with ZM 1.28.1
Looked into my logs and found theses messages
Date/Time
Component PID Level Message File Line
2015-10-26 18:15:25.607061 web_js 5526 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:19.064835 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:18.926082 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:18.785481 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 18:15:17.464982 web_js 5524 ERR TypeError: e[c] is undefined 8089/zm/tools/mootools/mootools-more.js 1
2015-10-26 21:05:39.600564 zms 1790 ERR Unable to send raw frame 95: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 21:05:23.399976 zms 1790 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:27.380748 zms 1774 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:23.985466 zms 1769 ERR Unable to send raw frame 69: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 21:04:18.489401 zms 1770 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:04:09.418709 zms 1769 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 21:03:58.144219 zms 1768 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 20:08:22.858043 zms 1616 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-26 20:08:21.383128 zms 1615 ERR Unable to send raw frame 53: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-26 20:08:13.463949 zms 1615 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
What do theses errors mean?
Re: TypeError from logs 1.28.1 ubuntu 15.10 x64
Posted: Tue Oct 27, 2015 12:58 am
by bbunge
What type of cameras are you running?
How much memory does your system have?
Do these errors show up only when you run Montage view?
bb
Posted: Tue Oct 27, 2015 1:03 pm
by ccjames9
bbunge wrote:What type of cameras are you running?
I am running an dit 4 bt878 capture card http://digi-it.co.kr/product/sub1.htm with 4 inputs but only using one input to my swann cam, No PTZ yet but ordered a PTZ serial port.
/etc/modprobe.d/bbtv.conf
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0
only CH4 on the card is working reset are blue (what is fine for my setup)
bbunge wrote:How much memory does your system have?
2gb ddr2 667mhz and also a intel dual core 2.80ghz (this is any help?)
bbunge wrote:Do these errors show up only when you run Montage view??
Dont think i have ever used it yet. Only click on Outside (name of my cam feed)
I cant give us the full logs as i have turned the system off overnight.
Date/Time
2015-10-27 12:44:26.540580 zms 1909 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:20.101540 zms 1908 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:15.198171 zms 1907 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:44:12.157910 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:43:49.406943 zms 1872 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:43:46.016980 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:43:13.371037 zms 1837 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:43:10.536910 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:59.526186 zms 1802 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:54.782240 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:42.579091 zms 1766 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:39.141540 zmdc 1150 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2015-10-27 12:42:27.194917 zms 1732 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:22.847194 zms 1731 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:42:17.622572 zms 1730 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:41:55.959527 zms 1729 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 12:41:44.170009 zms 1726 ERR Unable to send raw frame 183: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 12:41:23.332773 zms 1726 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:12:59.548140 zms 1553 ERR Unable to authenticate user /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zms.cpp 225
2015-10-27 11:03:16.347006 zms 1492 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:30.500319 zms 1458 ERR Unable to send raw frame 61: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 11:00:15.625564 zms 1458 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:15.601749 zms 1454 ERR Unable to send raw frame 61: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 11:00:13.100753 zms 1457 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 11:00:11.846850 zms 1455 ERR Unable to send stream frame: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1332
2015-10-27 11:00:07.191255 zms 1455 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:56.827984 zms 1454 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:43.473822 zms 1451 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:59:42.530708 zms 1450 ERR Unable to send raw frame 41: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:59:40.461516 zms 1450 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:50:20.893712 zms 1426 ERR Unable to send raw frame 84: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:50:09.856620 zms 1423 ERR Unable to send raw frame 69: Broken pipe /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_event.cpp 1316
2015-10-27 10:50:05.033351 zms 1426 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:49:55.313374 zms 1423 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:49:36.631124 zms 1421 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:41:10.012610 zms 1395 ERR Unable to authenticate user /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zms.cpp 225
2015-10-27 10:32:22.980376 zms 1253 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 426
2015-10-27 10:31:42.650510 zmdc 1150 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:42.593805 zma_m6 1225 ERR Shared data not initialised by capture daemon for monitor Outside /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 421
2015-10-27 10:31:42.478270 zmdc 1150 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:42.390980 zmdc 1150 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2015-10-27 10:31:41.881839 zma_m6 1201 ERR Got empty memory map file size 0, is the zmc process for this monitor running? /build/zoneminder-CtftjB/zoneminder-1.28.1/src/zm_monitor.cpp 513
