Event export generation incorrect paths
I posted earlier that almost every install of 1.28.1 the export function works but the paths are incorrectly generated.
Again, does anyone any one at all have a reason why it makes bad paths or a clue to what I might have done wrong in the setup.
help as always is greatly appreciated.
Re: Event export generation incorrect pathsu
You linked the answer to this question in your previous post. That link fully explains the issue and that it was fixed in master.
Thanks for the reply.
I know the fix is in the master. And by altering the error_reporting in my set up the event export in version 1.28.107 is working well.
It is only in my 1.28.1 install that export is always generating a path like USE_DEEP_STORAGE is not set.
Can I add the fix to existing 1.28.1 installs without an upgrade?
Sure. Since the changes were all done in php, you can make the change yourself w/o having to build from source.
The changes are shown in the link you referenced previsouly.
https://github.com/ZoneMinder/ZoneMinder/issues/506
Just click on commit d1f00f0 .
I made the changes....export works perfectly now. Thanks again.
