"Control Tab" ? (Solved)
Simpler
Post by Simpler »
I'm trying to setup control for my PTZ camera (IPCC-7210W) in ZoneMinder 1.28.107, and the documentation states "go to the Control tab of the Monitor configuration dialog".
http://zoneminder.readthedocs.org/en/la ... ntrol.html
My Monitor configuration dialog doesn't have a "Control" tab. I only see "General, Source, Timestamp, Buffers, Misc" tabs.
Do I need to set something else up first in order to get this Control tab?
Nerre
Re: "Control Tab" ?
Post by Nerre »
There is a setting in Options to enable camera controls.
Simpler
Re: "Control Tab" ?
Post by Simpler »
Nerre wrote:There is a setting in Options to enable camera controls.
That was it. Thanks.
