Event duration longer than parameters
bencollinz
Post by bencollinz »
This is happening frequently and starting to really annoy me as the action that I end up always needing is in this massive 2 hour video.
ZM 1.28.1 UB server 14.04.03 LTS
FFMPEG source
Any ideas?
Thank you
Ben
Re: Event duration longer than parameters
It is possible that you will have to change your motion detection settings.
or
if you are getting streaking in your image, which can happen with ffmpeg, that could be causing the l o n g event. Try forcing TCP to improve stream or slowing down camera frame rate/key frame interval.
bb
