28 on an OrangePi
liderbug
28 on an OrangePi
Post by liderbug »
Downloaded 28 to my OrangePi. Running cmake and having some problems - "can't find mysql.h" but it's there, so I commented it out. Now I'm up to polkit-gobject-1 not found but it's there also as is glib2 "missing" NOT. I'm not a cmake expert so I'm not sure how to handle this. Suggestions please.
thanks
asker
Re: 28 on an OrangePi
Post by asker »
There are ready made packages for pis which you might want to check before you dive in to cmake. Check the forum archives - there are various posts on it.
Please read before posting:
ES docs
zmNinja docs
If finding and using a package does not work, here is what I did in an OS that is between Debian and Ubuntu and neither packages worked without major issues.
I built a working ZoneMinder 1.28.109 on top of an XAMPP setup in a frugal install of Puppy Linux Tahr 6.0.3 using this:
git clone https://github.com/ZoneMinder/ZoneMinder.git
cd ZoneMinder/
git submodule init
git submodule update
cmake -DZM_WEBDIR=/opt/lampp/htdocs/zm -DZM_WEB_USER=daemon -DZM_WEB_GROUP=daemon -DZM_CGIDIR=/opt/lampp/cgi-bin .
make
make install
Important was getting these :libpolkit-gobject-1-dev_0.105-8_i386.deb and libmysqlclient-dev_5.5.41-0+wheezy1_i386.deb
these are Debian but loaded into the Puppy Linux OS and then by using CPANM added the necessary PERL modules that were not present
Date::Manip
LWP::UserAgent
DBD::mysql
Sys::Mmap
I had to also add MIME::Entity or MIME::Lite and Net::SMTP to get the email function to work well.
Most of my problems were solved by finding out what PERL mods were missing and adding them or which directory was missing and adding it.
Also check if all the necessary directories are present and ownership correct. example: /zm/temp, /zm/events, /zm/images, etc.
I could not just use cmake without changing parameters. The prep was key and cmake did give clues to what was missing.
maybe this info will help you get started.
liderbug
Post by liderbug »
Got up to cmake ... and <snip>
CMake Error at CMakeLists.txt:383 (message):
ZoneMinder requires mysqlclient but it was not found on your system
apt-get or dnf = Couldn't find package mysqlclient
and Google has been no help at all.
here I made these available to you:
they all worked for me, I used the latest from each.
https://drive.google.com/file/d/0By2RUs ... sp=sharing
libmysqlclient-dev_5.5.35+dfsg-2_i386.deb
libpolkit-gobject-1-dev_0.105-3_i386.deb
