Page 1 of 3
No Video (all else is fine) new install
Posted: Thu Nov 19, 2015 5:23 pm
by teraquad
I just completed a new installation of 1.28. it all appears to work except i have no video. I have had an easy time of it since i used 1.24 and 1.25 some years ago. I am certain the cameras are working as i get events when they occur and the console is working well.
The log says:[ invalid response status 404 : not found and unable to get response.
Any help with this would be much appropriated
Thanks, George....
Re: No Video (all else is fine) new install
Posted: Thu Nov 19, 2015 5:28 pm
by aaronl
404 is a standard http response code for "not found". It sounds like the url to your camera's video feed is incorrect.
Posted: Thu Nov 19, 2015 5:49 pm
by PacoLM
Try adding a /zm to your web path, for instance: 192.168.1.33:88/zm/index.php
Posted: Thu Nov 19, 2015 9:47 pm
by teraquad
I guess i am not being clear. I have the console with no problems. In fact i have 2 cameras with 30 some events each. that tells me that they are working, just not showing the video. I have 2 cameras that are not working and i presume to be the ones reporting as not found. the other 2 behave just fine and are the ones i am looking at. In fact i just deleted both dead ones and now all i have for a log is frame rates of 11 and 12 .
I am pretty sure the cameras are set up correctly and are running fine. Just missing video on the console.
Thanks! George....
Posted: Thu Nov 19, 2015 10:07 pm
by amckay
Hmmm, see my solution in the thread for the Foscam 9900 - could it be something like that?
Because my problem was pretty much exactly what you are experiencing.
Posted: Fri Nov 20, 2015 1:17 am
by asker
It's very hard to help you with just one line of a log.
1. Please post a snapshot of the general/source tabs of the camera settings (please mask IP/passwords as fit)
2. Please post detailed logs - please don't cherry pick only the final error message
3. When trying to view a live view, take a look at your apache error logs -- please post those logs too
Posted: Fri Nov 20, 2015 7:50 am
by teraquad
Here is the log file as it came up this morning. Not only are there frame rates but also some errors. Perhaps they will be helpful. This is an older machine but at 2.8 Ghz and 2 Gb ram it should work just fine I would think. Meanwhile I will do some studying on the problem and see what comes up.
2015-11-20 07:37:07.219888 zma_m4 3638 INF Driveway: 4000 - Processing at 10.53 fps zm_monitor.cpp 1160
2015-11-20 07:37:06.032307 zmc_m4 3608 INF Driveway: 4000 - Capturing at 10.64 fps zm_monitor.cpp 2907
2015-11-20 07:36:15.862541 zma_m2 3542 INF Barn: 3000 - Processing at 11.63 fps zm_monitor.cpp 1160
2015-11-20 07:36:15.045051 zmc_m2 3513 INF Barn: 3000 - Capturing at 11.63 fps zm_monitor.cpp 2907
2015-11-20 07:35:32.914526 zma_m4 3638 INF Driveway: 3000 - Processing at 14.49 fps zm_monitor.cpp 1160
2015-11-20 07:35:32.190149 zmc_m4 3608 INF Driveway: 3000 - Capturing at 14.29 fps zm_monitor.cpp 2907
2015-11-20 07:34:49.798555 zma_m2 3542 INF Barn: 2000 - Processing at 12.05 fps zm_monitor.cpp 1160
2015-11-20 07:34:49.289053 zmc_m2 3513 INF Barn: 2000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-20 07:34:23.070070 zma_m4 3638 INF Driveway: 2000 - Processing at 14.29 fps zm_monitor.cpp 1160
2015-11-20 07:34:22.358254 zmc_m4 3608 INF Driveway: 2000 - Capturing at 14.49 fps zm_monitor.cpp 2907
2015-11-20 07:33:26.485857 zma_m2 3542 INF Barn: 1000 - Processing at 12.05 fps zm_monitor.cpp 1160
2015-11-20 07:33:25.961976 zmc_m2 3513 INF Barn: 1000 - Capturing at 12.05 fps zm_monitor.cpp 2907
2015-11-20 07:33:13.879120 zma_m4 3638 INF Driveway: 1000 - Processing at 14.49 fps zm_monitor.cpp 1160
2015-11-20 07:33:13.232376 zmc_m4 3608 INF Driveway: 1000 - Capturing at 14.29 fps zm_monitor.cpp 2907
2015-11-20 07:32:42.677049 web_php 3065 ERR socket_sendto( /var/lib/zoneminder/sock/zms-777685s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-20 07:32:32.458735 web_php 3061 ERR socket_sendto( /var/lib/zoneminder/sock/zms-777685s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-20 07:32:08.026970 zmaudit 3755 INF deleting zmaudit.pl
2015-11-20 07:32:07.968990 zmaudit 3755 INF Filesystem event '4/70' does not exist in database zmaudit.pl
2015-11-20 07:32:07.799930 zmaudit 3755 INF deleting zmaudit.pl
2015-11-20 07:32:07.744460 zmaudit 3755 INF Filesystem event '2/69' does not exist in database zmaudit.pl
2015-11-20 07:32:07.572190 zmaudit 3755 INF deleting zmaudit.pl
2015-11-20 07:32:07.538310 zmaudit 3755 INF Found empty event with no frame records '70' zmaudit.pl
2015-11-20 07:32:07.454460 zmwatch 3822 INF Watchdog pausing for 30 seconds zmwatch.pl
2015-11-20 07:32:07.377170 zmwatch 3822 INF Watchdog starting zmwatch.pl
2015-11-20 07:32:07.287120 zmdc 3877 INF 'zmupdate.pl -c' started at 15/11/20 02:32:07 zmdc.pl
2015-11-20 07:32:07.283820 zmdc 3297 INF 'zmupdate.pl -c' starting at 15/11/20 02:32:07, pid = 3877 zmdc.pl
2015-11-20 07:32:07.228670 zmaudit 3755 INF deleting zmaudit.pl
2015-11-20 07:32:07.103530 zmaudit 3755 INF Found empty event with no frame records '69' zmaudit.pl
2015-11-20 07:32:07.006000 zmfilter 3692 INF Scanning for events zmfilter.pl
2015-11-20 07:32:06.464130 zmdc 3822 INF 'zmwatch.pl' started at 15/11/20 02:32:06 zmdc.pl
2015-11-20 07:32:06.452360 zmdc 3297 INF 'zmwatch.pl' starting at 15/11/20 02:32:06, pid = 3822 zmdc.pl
2015-11-20 07:32:06.111177 zma_m4 3638 INF Driveway: 026 - Opening new event 72, section start zm_monitor.cpp 1405
2015-11-20 07:32:05.449330 zmdc 3297 INF 'zmaudit.pl -c' starting at 15/11/20 02:32:05, pid = 3755 zmdc.pl
2015-11-20 07:32:05.445300 zmdc 3755 INF 'zmaudit.pl -c' started at 15/11/20 02:32:05 zmdc.pl
2015-11-20 07:32:05.285081 zma_m2 3542 INF Barn: 026 - Opening new event 71, section start zm_monitor.cpp 1405
2015-11-20 07:32:04.665760 zmdc 3692 INF 'zmfilter.pl' started at 15/11/20 02:32:04 zmdc.pl
2015-11-20 07:32:04.663930 zmdc 3297 INF 'zmfilter.pl' starting at 15/11/20 02:32:04, pid = 3692 zmdc.pl
2015-11-20 07:32:04.271514 zma_m4 3638 INF In mode 5/1, warming up zma.cpp 105
2015-11-20 07:32:04.094100 zmdc 3638 INF 'zma -m 4' started at 15/11/20 02:32:04 zmdc.pl
2015-11-20 07:32:04.091050 zmdc 3297 INF 'zma -m 4' starting at 15/11/20 02:32:04, pid = 3638 zmdc.pl
2015-11-20 07:32:03.976522 zmc_m4 3608 INF Starting Capture zmc.cpp 195
2015-11-20 07:32:03.727740 zmdc 3608 INF 'zmc -m 4' started at 15/11/20 02:32:03 zmdc.pl
2015-11-20 07:32:03.724880 zmdc 3297 INF 'zmc -m 4' starting at 15/11/20 02:32:03, pid = 3608 zmdc.pl
2015-11-20 07:32:03.686750 zmdc 3297 INF Starting pending process, zmc -m 4 zmdc.pl
2015-11-20 07:32:03.654910 zmdc 3297 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-11-20 07:32:03.530790 zmdc 3587 INF 'zmc -m 4' started at 15/11/20 02:32:03 zmdc.pl
2015-11-20 07:32:03.528550 zmdc 3297 INF 'zmc -m 4' starting at 15/11/20 02:32:03, pid = 3587 zmdc.pl
2015-11-20 07:32:03.201007 zma_m2 3542 INF In mode 5/1, warming up zma.cpp 105
2015-11-20 07:32:03.052370 zmdc 3542 INF 'zma -m 2' started at 15/11/20 02:32:03 zmdc.pl
2015-11-20 07:32:03.050130 zmdc 3297 INF 'zma -m 2' starting at 15/11/20 02:32:03, pid = 3542 zmdc.pl
2015-11-20 07:32:02.983707 zmc_m2 3513 INF Starting Capture zmc.cpp 195
2015-11-20 07:32:02.767960 zmdc 3513 INF 'zmc -m 2' started at 15/11/20 02:32:02 zmdc.pl
2015-11-20 07:32:02.755690 zmdc 3297 INF 'zmc -m 2' starting at 15/11/20 02:32:02, pid = 3513 zmdc.pl
2015-11-20 07:32:02.718730 zmdc 3297 INF Starting pending process, zmc -m 2 zmdc.pl
2015-11-20 07:32:02.681720 zmdc 3297 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2015-11-20 07:32:02.499090 zmdc 3486 INF 'zmc -m 2' started at 15/11/20 02:32:02 zmdc.pl
2015-11-20 07:32:02.496830 zmdc 3297 INF 'zmc -m 2' starting at 15/11/20 02:32:02, pid = 3486 zmdc.pl
2015-11-20 07:31:59.119860 zmdc 3297 INF Server starting at 15/11/20 02:31:59 zmdc.pl
2015-11-20 07:31:57.945470 zmpkg 3162 INF Command: start zmpkg.pl
2015-11-20 07:31:10.056800 zmpkg 3033 INF Command: start zmpkg.pl
2015-11-19 22:00:09.702780 zmdc 3509 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2015-11-19 22:00:08.802860 zmdc 3509 INF 'zmc -m 4' exited normally zmdc.pl
2015-11-19 22:00:07.850120 zmdc 3509 INF 'zmwatch.pl ' exited, signal 14 zmdc.pl
2015-11-19 22:00:06.912790 zmdc 3509 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2015-11-19 22:00:03.553070 zma_m2 16888 INF Barn: 244423 - Opening new event 69, section start zm_monitor.cpp 1405
2015-11-19 22:00:03.277568 zma_m4 15770 INF Driveway: 257843 - Opening new event 70, section start zm_monitor.cpp 1405
2015-11-19 22:00:03.187150 zmdc 3509 INF 'zmfilter.pl ' exited, signal 14 zmdc.pl
2015-11-19 22:00:02.994097 zma_m2 16888 INF Got signal 1 (Hangup), reloading zm_signal.cpp 34
2015-11-19 22:00:02.768946 zma_m4 15770 INF Got signal 1 (Hangup), reloading zm_signal.cpp 34
2015-11-19 22:00:02.395584 zma_m2 16888 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-11-19 22:00:02.182210 zma_m4 15770 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-11-19 22:00:00.185616 zmc_m4 15758 INF Driveway: 260000 - Capturing at 14.29 fps zm_monitor.cpp 2907
2015-11-19 22:00:00.046244 zma_m4 15770 INF Driveway: 257843 - Closing event 67, section end zm_monitor.cpp 1385
2015-11-19 22:00:00.026014 zma_m2 16888 INF Barn: 244423 - Closing event 68, section end zm_monitor.cpp 1385
2015-11-19 21:59:51.928245 zmc_m2 16879 INF Barn: 246000 - Capturing at 12.05 fps zm_monitor.cpp 2907
2015-11-19 21:59:24.598591 zma_m2 16888 INF Barn: 244000 - Processing at 12.05 fps zm_monitor.cpp 1160
2015-11-19 21:59:01.157303 zma_m4 15770 INF Driveway: 257000 - Processing at 14.08 fps zm_monitor.cpp 1160
2015-11-19 21:58:50.123327 zmc_m4 15758 INF Driveway: 259000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-19 21:58:28.264397 zmc_m2 16879 INF Barn: 245000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-19 21:58:01.079199 zma_m2 16888 INF Barn: 243000 - Processing at 11.90 fps zm_monitor.cpp 1160
2015-11-19 21:57:50.961257 zma_m4 15770 INF Driveway: 256000 - Processing at 12.20 fps zm_monitor.cpp 1160
2015-11-19 21:57:38.749475 zmc_m4 15758 INF Driveway: 258000 - Capturing at 12.05 fps zm_monitor.cpp 2907
2015-11-19 21:57:04.789108 zmc_m2 16879 INF Barn: 244000 - Capturing at 11.76 fps zm_monitor.cpp 2907
2015-11-19 21:56:37.195839 zma_m2 16888 INF Barn: 242000 - Processing at 11.63 fps zm_monitor.cpp 1160
2015-11-19 21:56:28.887504 zma_m4 15770 INF Driveway: 255000 - Processing at 11.90 fps zm_monitor.cpp 1160
2015-11-19 21:56:15.909121 zmc_m4 15758 INF Driveway: 257000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-19 21:55:39.361169 zmc_m2 16879 INF Barn: 243000 - Capturing at 11.49 fps zm_monitor.cpp 2907
2015-11-19 21:55:11.023878 zma_m2 16888 INF Barn: 241000 - Processing at 11.49 fps zm_monitor.cpp 1160
2015-11-19 21:55:04.278057 zma_m4 15770 INF Driveway: 254000 - Processing at 11.49 fps zm_monitor.cpp 1160
2015-11-19 21:54:51.497701 zmc_m4 15758 INF Driveway: 256000 - Capturing at 11.63 fps zm_monitor.cpp 2907
2015-11-19 21:54:12.693277 zmc_m2 16879 INF Barn: 242000 - Capturing at 11.76 fps zm_monitor.cpp 2907
2015-11-19 21:53:44.682098 zma_m2 16888 INF Barn: 240000 - Processing at 11.76 fps zm_monitor.cpp 1160
2015-11-19 21:53:37.513931 zma_m4 15770 INF Driveway: 253000 - Processing at 12.50 fps zm_monitor.cpp 1160
2015-11-19 21:53:25.595248 zmc_m4 15758 INF Driveway: 255000 - Capturing at 12.66 fps zm_monitor.cpp 2907
2015-11-19 21:52:47.404315 zmc_m2 16879 INF Barn: 241000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-19 21:52:19.641783 zma_m2 16888 INF Barn: 239000 - Processing at 12.05 fps zm_monitor.cpp 1160
2015-11-19 21:52:17.081067 zma_m4 15770 INF Driveway: 252000 - Processing at 14.08 fps zm_monitor.cpp 1160
2015-11-19 21:52:06.341548 zmc_m4 15758 INF Driveway: 254000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-19 21:51:23.740344 zmc_m2 16879 INF Barn: 240000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-19 21:51:06.393971 zma_m4 15770 INF Driveway: 251000 - Processing at 12.20 fps zm_monitor.cpp 1160
2015-11-19 21:50:56.330591 zma_m2 16888 INF Barn: 238000 - Processing at 11.76 fps zm_monitor.cpp 1160
2015-11-19 21:50:54.440409 zmc_m4 15758 INF Driveway: 253000 - Capturing at 11.90 fps zm_monitor.cpp 2907
2015-11-19 21:50:00.356735 zma_m2 16888 INF Barn: 237335 - Opening new event 68, section start zm_monitor.cpp 1405
2015-11-19 21:50:00.246645 zma_m4 15770 INF Driveway: 250187 - Opening new event 67, section start zm_monitor.cpp 1405
2015-11-19 21:50:00.082273 zma_m2 16888 INF Barn: 237335 - Closing event 65, section end zm_monitor.cpp 1385
2015-11-19 21:50:00.003848 zma_m4 15770 INF Driveway: 250187 - Closing event 66, section end zm_monitor.cpp 1385
Thanks for the information perhaps this will help.
Thanks! george....
Posted: Fri Nov 20, 2015 8:08 am
by teraquad
Here is the error log file.
Apache log file Error:
[Thu Nov 19 04:53:12.842542 2015] [:error] [pid 4443] [client 192.168.1.70:43328] PHP Warning: strtotime(): Invalid date.timezone value 'America/New_York ', we selected the timezone 'UTC' for now. in /usr/share/zoneminder/www/includes/functions.php on line 1434, referer: http://192.168.1.70/zm/index.php
[Thu Nov 19 04:53:12.842587 2015] [:error] [pid 4443] [client 192.168.1.70:43328] PHP Warning: strftime(): Invalid date.timezone value 'America/New_York ', we selected the timezone 'UTC' for now. in /usr/share/zoneminder/www/includes/functions.php on line 1434, referer: http://192.168.1.70/zm/index.php
[Thu Nov 19 04:53:12.843983 2015] [:error] [pid 4443] [client 192.168.1.70:43328] PHP Warning: strtotime(): Invalid date.timezone value 'America/New_York ', we selected the timezone 'UTC' for now. in /usr/share/zoneminder/www/includes/functions.php on line 1434, referer: http://192.168.1.70/zm/index.php
[Thu Nov 19 04:53:12.844051 2015] [:error] [pid 4443] [client 192.168.1.70:43328] PHP Warning: strftime(): Invalid date.timezone value 'America/New_York ', we selected the timezone 'UTC' for now. in /usr/share/zoneminder/www/includes/functions.php on line 1434, referer: http://192.168.1.70/zm/index.php
[Thu Nov 19 04:53:12.844200 2015] [:error] [pid 4443] [client 192.168.1.70:43328] PHP Warning: strtotime(): Invalid date.timezone value 'America/New_York ', we selected the timezone 'UTC' for now. in /usr/share/zoneminder/www/includes/functions.php on line 1434, referer: http://192.168.1.70/zm/index.php
I hope this helps, I wonder where i fix this error.
Thanks george....
Posted: Fri Nov 20, 2015 9:01 am
by PacoLM
Posted: Fri Nov 20, 2015 9:02 am
by PacoLM
find / -name php.ini
Posted: Fri Nov 20, 2015 1:31 pm
by teraquad
find: ‘/run/user/1000/gvfs’: Permission denied
find: ‘/run/user/42/gvfs’: Permission denied
/etc/php.ini
Posted: Fri Nov 20, 2015 2:01 pm
by knight-of-ni
@teraquad I think I had helped you a year or two ago. At the time, you were running Fedora. Is this still the case?
If you are running a Redhat distro, you should install zoneminder via zmrepo:
http://zmrepo.zoneminder.com/
Follow the instructions, exactly, and you should not have any problems. The timezone issue you posted previously, is documented in the instructions.
Posted: Fri Nov 20, 2015 2:37 pm
by rockedge
knnniggett wrote:@teraquad Follow the instructions, exactly, and you should not have any problems. The timezone issue you posted previously, is documented in the instructions.
I have this timezone error endlessly as well.
I need this fix for a Puppy Linux install. What is it exactly?
Posted: Fri Nov 20, 2015 2:50 pm
by knight-of-ni
https://github.com/ZoneMinder/ZoneMinde ... DME.Fedora
See item #4 under New Installs.
These instructions are specific to Fedora so the steps may not apply or may not be the same for your distro.
Posted: Fri Nov 20, 2015 3:34 pm
by PacoLM
sudo find / -name php.ini
