[SOLVED] too much delay between opening windows and start streaming
Posted: Sun Nov 22, 2015 3:01 pm
(SOLVED: check your web protection software: in my case sophos web protection was doing nasty things with local connections)
Hi all, i'm not new to zoneminder (in fact, i'm using it from 2010), but now i have some issues with fresh installed debian jessie and zoneminder 1.28.1
The problem which i can't solve is the 10-20 seconds delay between stream window opening (i tried with firefox and chrome with same results) before start to getting (delayed by 2-3 seconds) images.
The pc i'm using is the same about 3 years (i removed old fedora 19) and it's working fine.
Can anyone help me?
cpu isn't overloaded (it's between 5-6% of load).
Can anyone help me?
