1.28.109 install
stevewrightnz1
1.28.109 install
Post by stevewrightnz1 »
OK - this might be a pretty basic question or even the wrong place to ask it?
Ubuntu 14.04.3 LTS desktop 64bit
I have managed to get 1.28.1 installed and running albeit without the video streaming working - that one I'm working on still.
The process for fixing the install here https://wiki.zoneminder.com/Common_Issu ... _on_Ubuntu uses a repo here
add-apt-repository ppa:iconnor/zoneminder. This works OK except for the aforementioned missing video stream.
I have also had a bit of a poke around on the website and found this https://launchpad.net/~iconnor/+archive ... /+packages
Looks like a build of 1.28.109?
My question is - Can I download and install this using apt if I add another repo? if so what do I use??
Can I just download the files and use dpkg to install??
Steve
Re: 1.28.109 install
The answer to you question is documented here:
Your issue with the video is likely solved by enabling CGI in Apache. See the Ubuntu server section in the WIKI.
I just noticed that there is a new version of 1.28.109 in the PPA master for Ubuntu Trusty and WIley. I have not rin these as upgrades, yet, to see if the upgrade instruction are accurate. I ran the upgrade for Vivid yesterday and added notes to the upgrade instructions. With some family business to do in the next few days I may not have a chance to "test" the new versions. I suspect that the database will upgrade when the upgrade is run like Vivid. I was able to do a fresh install with the Vivid PPA version but have not documented it...yet.
Stay tuned folks... as they say...film at 11:00 (or 2200).
bb
I was able to do a quick verify with slight mods to:
https://wiki.zoneminder.com/Common_Issu ... PA_version
Upgraded Ubuntu 14.04-3 ZM 1.26.5 to current 1.28.109.
bb
Procedure to upgrade Ubuntu 15.10 ZM 1.28.1 to PPA master 1.28.109:
stevewrightnz1
I can confirm that it works for
Ubuntu 14.04 with MySQL 5.6 and Zoneminder from PPA
just add the repo
add-apt-repository ppa:iconnor/zoneminder-master
and follow the instructions:)
It even fixed my missing video - yay
