ZmView Changing Function disables Camera but works.
FreeSoftwareServers
Post by FreeSoftwareServers »
So I know this is technically a ZmView problem, but instead of try to fix the app, I wondered if I could do anything on the Server side.
The Problem:
Changing a camera from Monitor to Motion or anything else works but disables camera. (Checking in WebUI after changes via App)
Questions to Fix:
Can I disable disabling cameras?
Can I enable a camera via Command Line?
*Any Ideas on fixing the App, is it an App Issue or a Server Config issue I can work on.
I read about the new API, but I got the impression that this App would just fail if it wasn't using the new API and still using XML. I installed latest version as of 12.8.15 which I believe is 1.28.*. I used the PPA, I didn't compile myself.
Need any more information let me know.
PS: Server is Ubuntu 14.04 x64 SE
Re: ZmView Changing Function disables Camera but works.
There were similar issues reported with a Debian install. I have not tried ZMview with the version from the PPA master. I do know it works with 1.28.107. As of now you have the choice of going back to 1.28.1 or not. Will post if I come up with something useful.
FreeSoftwareServers
I am trying the new API install via ppa:iconnor/zoneminder-master but I got an error ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone, but I am going to try ZmNinja as it looks to be the future and I am just getting my feet wet. Might as well start with the times.
Working on solving it now... Found this
http://php.net/manual/en/function.date- ... ne-set.php
But don't know how to implement it yet
FreeSoftwareServers
/etc/php5/apache2/php.ini Time Zone Formats
; Module Settings ;
[CLI Server]
; Whether the CLI web server uses ANSI color coding in its terminal output.
cli_server.color = On
[Date]
Will Update on ZMNinja status if I get it working.
They fixed the app. New version 09DEC15
FreeSoftwareServers
I already switched to Api and am using zmNinja and I don't regret it. I got the pro ZmView for that feature specifically and it didn't work OOB. ZmNinja took some tweaking but it is well documented and works awesome now!
I will be continuing my adventures with ZmNinja on my blog/website >> https://www.freesoftwareservers.com/ind ... oneminder/
