ZmView Changing Function disables Camera but works.
Posted: Wed Dec 09, 2015 2:30 am
So I know this is technically a ZmView problem, but instead of try to fix the app, I wondered if I could do anything on the Server side.
The Problem:
Changing a camera from Monitor to Motion or anything else works but disables camera. (Checking in WebUI after changes via App)
Questions to Fix:
Can I disable disabling cameras?
Can I enable a camera via Command Line?
*Any Ideas on fixing the App, is it an App Issue or a Server Config issue I can work on.
I read about the new API, but I got the impression that this App would just fail if it wasn't using the new API and still using XML. I installed latest version as of 12.8.15 which I believe is 1.28.*. I used the PPA, I didn't compile myself.
Need any more information let me know.
PS: Server is Ubuntu 14.04 x64 SE
The Problem:
Questions to Fix:
