How can I setup serial RS 422 PTZ in ZM
Hello Guys,
I been searching for how you can setup a local PTZ camera using serial RS422. I've seen documentation for network Ptz but not local serial. Can any one guide through this setup?
- knight-of-ni
Re: How can I setup serial RS 422 PTZ in ZM
We can't give you a precise answer because you've neglected to tell us what hardware you have and how you have the rs422 wired to your machine.
Looks like we also need to know the baud rate of your equipment. It should be either 2400 or 4800.
Generally, you need to select either the PelcoP of PelcoD control script for the camera in question and enter the serial device into the Control Device field.
Hi sorry for the less info.
Hardware is
American Dynamics Ultra 8 dome camera
Set to Pelco P 9600 RS 422
Connected to
RS232 to Rs422 4 wire configuration
PC is levnovo running Ubuntu
The equipment have been tested on Windows PCs with a Ptz test software.
I have entered the Pelco P, and serial /dev/ttyS0 for serial 1.
Is there any other configuration?
Hardware is
Connected to
So in config I entered these values
'PELCO-D'
'Control Device' /dev/ttyS0 or /dev/ttyS1 (serial 0 or 1 I tried both)
'Control Address' 2
'Auto Stop' to 1.00
No Track Motion
'PELCO-D'
'Control Address' 2
'Auto Stop' to 1.00
No Track Motion
Also to mention on my RS 232 to RS 422 I have transmit and receive l.e.d's which are inactive when trying to send commands to the camera.
Hi just an update
I have transmit light working.
before i check to see if the com port was working so i send a command echo -ne '\033[2J' > /dev/ttyS0
the transmit functioned.
i tried in ZM I got no response.
I found out i had to adduser www-data dialout
Now I tried again in ZM this time I got some activity.
now with the camera attached and set too 4800 Pelco P with address 2 I cannot get the camera to turn
my ZM settings are:
Control tab
controllable checked
control type Pelco P
control device /dev/ttyS0
Control address 0
Auto Stop Timeout 1.00
track motion off
track delay 0
return location none
return delay 0
Source tab
device channel 2
my ZM settings are:
Control tab
Control address 0
track motion off
track delay 0
return delay 0
Source tab
device channel 2
My logs are showing this:
2015-12-13 00:05:39.327386 web_php 2974 ERR /usr/bin/zmcontrol.pl --panspeed=46 --autostop --command=moveConRight --id=6=> /usr/share/zoneminder/includes/functions.php 2330
2015-12-13 00:05:39.233640 zmcontrol 3600 FAT Can't connect: No such file or directory zmcontrol.pl
2015-12-13 00:05:31.188377 zmc_m2 3382 INF Back-graden: 23000 - Capturing at 13.16 fps zm_monitor.cpp 2907
2015-12-13 00:05:29.232500 zmcontrol 3602 INF Control server 6/PelcoP starting at 15/12/13 00:05:29 zmcontrol.pl
2015-12-13 00:05:29.104280 zmcontrol 3600 INF Starting control server 6/PelcoP zmcontrol.pl
2015-12-13 00:05:28.923391 web_php 2526 ERR /usr/bin/zmcontrol.pl --panspeed=35 --autostop --command=moveConRight --id=6=> /usr/share/zoneminder/includes/functions.php 2330
2015-12-13 00:05:28.856870 zmcontrol 3596 FAT Can't connect: No such file or directory zmcontrol.pl
2015-12-13 00:05:18.855740 zmcontrol 3598 INF Control server 6/PelcoP starting at 15/12/13 00:05:18 zmcontrol.pl
2015-12-13 00:05:18.779080 zmcontrol 3596 INF Starting control server 6/PelcoP zmcontrol.pl
2015-12-13 00:05:18.599299 web_php 2546 ERR /usr/bin/zmcontrol.pl --panspeed=32 --autostop --command=moveConRight --id=6=> /usr/share/zoneminder/includes/functions.php 2330
2015-12-13 00:05:18.539090 zmcontrol 3589 FAT Can't connect: No such file or directory zmcontrol.pl
2015-12-13 00:05:08.537950 zmcontrol 3592 INF Control server 6/PelcoP starting at 15/12/13 00:05:08 zmcontrol.pl
2015-12-13 00:05:08.467120 zmcontrol 3589 INF Starting control server 6/PelcoP zmcontrol.pl
2015-12-13 00:05:08.272799 web_php 3113 ERR socket_sendto( /var/run/zm/zms-630592s.sock ) failed: No such file or directory
Any ideas guys,
I was also think do I need to change the serial port 1 to 4800 or leave it at default 115200. As ZM Pelco P is at 4800. I notice on the my Windows machine I didn't have to do this just had to select 9600 (at the time) in the software.
- knight-of-ni
It looks like you are doing it correctly. The ZoneMinder Pelco P control script expects the receiving device to be at 4800 baud, which it looks like you've set. You've also verified the LED's on the 232/422 are indicating activity. I would not expect a need to mess with the port settings of the serial port.
What I would do next is get a laptop. Tie the serial port of the laptop to the serial port of the zoneminder machine with a null modem cable.
Using your favorite terminal program on the laptop, record the ascii ptz commands being sent out of the port from the zoneminder server.
Now repeat this test using the (Windows) machine that works correctly.
Now compare the two outputs. Is there a difference?
Hi thanks for the reply.
I will try what you said with the laptop.
However if i send a pan up command through Zoneminder i get this error:
I've i changed the Control.pm script to this:
To me it's like Zoneminders not talking to /dev/ttyS0
I removed /dev/ttyS0 from the X10 option in case there was conflict.
Besides the option Control Device is there any place i need it point to com 1?
- Control response was status = undefined
message = /usr/bin/zmcontrol.pl --tiltspeed=27 --autostop --command=moveConUp --id=6=>
# ZoneMinder Pelco-P Control Protocol Module, $Date$, $Revision$
# This module contains the implementation of the Pelco-P camera control
# protocol
package ZoneMinder::Control::PelcoP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Pelco-P Control Protocol
use Time::HiRes qw( usleep );
use constant STX => 0xa0;
use constant ETX => 0xaf;
use constant COMMAND_GAP => 100000; # In ms
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use Device::SerialPort;
$self->{port} = new Device::SerialPort( $self->{Monitor}->{ControlDevice} );
$self->{port}->baudrate(4800);
$self->{port}->databits(8);
$self->{port}->parity('none');
$self->{port}->stopbits(1);
$self->{port}->handshake('none');
$self->{port}->read_const_time(50);
$self->{port}->read_char_time(10);
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
$self->{port}->close();
sub printMsg
if ( logDebugging() )
my $self = shift;
my $msg = shift;
my $prefix = shift || "";
$prefix = $prefix.": " if ( $prefix );
my $line_length = 16;
my $msg_len = int(@$msg);
my $msg_str = $prefix;
for ( my $i = 0; $i < $msg_len; $i++ )
if ( ($i > 0) && ($i%$line_length == 0) && ($i != ($msg_len-1)) )
$msg_str .= sprintf( "\n%*s", length($prefix), "" );
$msg_str .= sprintf( "%02x ", $msg->[$i] );
$msg_str .= "[".$msg_len."]";
Debug( $msg_str );
sub sendCmd
my $self = shift;
my $cmd = shift;
my $ack = shift || 0;
my $result = undef;
my $checksum = 0x00;
for ( my $i = 1; $i < int(@$cmd); $i++ )
$checksum ^= $cmd->[$i];
$checksum &= 0xff;
push( @$cmd, $checksum );
$self->printMsg( $cmd, "Tx" );
my $id = $cmd->[0] & 0xf;
my $tx_msg = pack( "C*", @$cmd );
#print( "Tx: ".length( $tx_msg )." bytes\n" );
my $n_bytes = $self->{port}->write( $tx_msg );
if ( !$n_bytes )
Error( "Write failed: $!" );
if ( $n_bytes != length($tx_msg) )
Error( "Incomplete write, only ".$n_bytes." of ".length($tx_msg)." written: $!" );
if ( $ack )
Debug( "Waiting for ack" );
my $max_wait = 3;
my $now = time();
while( 1 )
my ( $count, $rx_msg ) = $self->{port}->read(4);
if ( $count )
#print( "Rx1: ".$count." bytes\n" );
my @resp = unpack( "C*", $rx_msg );
printMsg( \@resp, "Rx" );
if ( $resp[0] = 0x80 + ($id<<4) )
if ( ($resp[1] & 0xf0) == 0x40 )
my $socket = $resp[1] & 0x0f;
Debug( "Got ack for socket $socket" );
$result = !undef;
else
Error( "Got bogus response" );
last;
else
Error( "Got message for camera ".(($resp[0]-0x80)>>4) );
if ( (time() - $now) > $max_wait )
Warning( "Response timeout" );
last;
sub remoteReset
my $self = shift;
Debug( "Remote Reset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0f, 0x00, 0x00, ETX );
$self->sendCmd( \@msg );
sub resetDefaults
my $self = shift;
Debug( "Reset Defaults" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x29, 0x00, 0x00, ETX );
sub cameraOff
my $self = shift;
Debug( "Camera Off" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x08, 0x00, 0x00, 0x00, ETX );
sub cameraOn
my $self = shift;
Debug( "Camera On" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x88, 0x00, 0x00, 0x00, ETX );
sub autoScan
my $self = shift;
Debug( "Auto Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x90, 0x00, 0x00, 0x00, ETX );
sub manScan
my $self = shift;
Debug( "Manual Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x10, 0x00, 0x00, 0x00, ETX );
sub stop
my $self = shift;
Debug( "Stop" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x00, 0x00, 0x00, ETX );
sub moveConUp
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'tiltspeed' );
my $autostop = $self->getParam( $params, 'autostop', 0 );
Debug( "Move Up" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x08, 0x00, $speed, ETX );
if( $autostop && $self->{Monitor}->{AutoStopTimeout} )
usleep( $self->{Monitor}->{AutoStopTimeout} );
$self->stop( $params );
sub moveConDown
my $self = shift;
my $params = shift;
Debug( "Move Down" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x10, 0x00, $speed, ETX );
$self->stop();
sub moveConLeft
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x04, $speed, 0x00, ETX );
$self->stop();
sub moveConRight
my $self = shift;
my $params = shift;
Debug( "Move Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x02, $speed, 0x00, ETX );
$self->stop();
sub moveConUpLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed', 0x3f );
my $tiltspeed = $self->getParam( $params, 'tiltspeed', 0x3f );
Debug( "Move Up/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0c, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0a, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownLeft
my $self = shift;
my $params = shift;
Debug( "Move Down/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x14, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownRight
my $self = shift;
my $params = shift;
Debug( "Move Down/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x12, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveStop
my $self = shift;
Debug( "Move Stop" );
$self->stop();
sub flip180
my $self = shift;
Debug( "Flip 180" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x21, ETX );
sub zeroPan
my $self = shift;
Debug( "Zero Pan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x22, ETX );
sub _setZoomSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Zoom Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x25, 0x00, $speed, ETX );
sub zoomStop
my $self = shift;
Debug( "Zoom Stop" );
$self->stop();
$self->_setZoomSpeed( 0 );
sub zoomConTele
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x01 );
Debug( "Zoom Tele" );
$self->_setZoomSpeed( $speed );
usleep( COMMAND_GAP );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x20, 0x00, 0x00, ETX );
$self->zoomStop();
sub zoomConWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x40, 0x00, 0x00, ETX );
$self->zoomStop();
sub _setFocusSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Focus Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x27, 0x00, $speed, ETX );
sub focusConNear
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x03 );
Debug( "Focus Near" );
$self->_setFocusSpeed( $speed );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x01, 0x00, 0x00, 0x00, ETX );
$self->_setFocusSpeed( 0 );
sub focusConFar
my $self = shift;
my $params = shift;
Debug( "Focus Far" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x80, 0x00, 0x00, ETX );
sub focusStop
my $self = shift;
Debug( "Focus Stop" );
$self->stop();
sub focusAuto
my $self = shift;
Debug( "Focus Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x00, ETX );
sub focusMan
my $self = shift;
Debug( "Focus Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x02, ETX );
sub _setIrisSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Iris Speed $speed" );
sub irisConClose
my $self = shift;
my $params = shift;
Debug( "Iris Close" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x04, 0x00, 0x00, 0x00, ETX );
$self->_setIrisSpeed( 0 );
sub irisConOpen
my $self = shift;
my $params = shift;
Debug( "Iris Open" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x02, 0x80, 0x00, 0x00, ETX );
sub irisStop
my $self = shift;
Debug( "Iris Stop" );
$self->stop();
sub irisAuto
my $self = shift;
Debug( "Iris Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x00, ETX );
sub irisMan
my $self = shift;
Debug( "Iris Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x02, ETX );
sub writeScreen
my $self = shift;
my $params = shift;
my $string = $self->getParam( $params, 'string' );
Debug( "Writing '$string' to screen" );
my @chars = unpack( "C*", $string );
for ( my $i = 0; $i < length($string); $i++ )
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x15, $i, $chars[$i], ETX );
sub clearScreen
my $self = shift;
Debug( "Clear Screen" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x17, 0x00, 0x00, ETX );
sub clearPreset
my $self = shift;
my $params = shift;
my $preset = $self->getParam( $params, 'preset', 1 );
Debug( "Clear Preset $preset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x05, 0x00, $preset, ETX );
sub presetSet
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x03, 0x00, $preset, ETX );
sub presetGoto
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, $preset, ETX );
sub presetHome
my $self = shift;
Debug( "Home Preset" );
sub reset
my $self = shift;
Debug( "Reset" );
$self->remoteReset();
$self->resetDefaults();
sub wake
my $self = shift;
Debug( "Wake" );
$self->cameraOn();
sub sleep
my $self = shift;
Debug( "Sleep" );
$self->cameraOff();
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
use ZoneMinder::Database;
blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
just to make clear where i said its working in zoneminder its stopped working with no changes just reboot. but if send the command manually it still sends in terminal.Zmptz wrote:Hi just an update
has anyone got good instruction on how to setup Pelco P PTZ on zoneminder?
Update: strange thing happened, I left the zoneminder PCs on for three day without touching it and now if I send a move command the Tx lights start flashing. However if I do too many commands then it stops flashing.
Not sure this might be indicator the com port buffer getting full because it can't transmit and receive to clear message.
Any ideas will be appreciated
with this being the ERROR im getting does it mean i need to configure the Pelco P script? Also How?
2015-12-23 22:11:28.637419 web_php 17672 ERR /usr/bin/zmcontrol.pl --panspeed=35 --autostop --command=moveConRight --id=4=> /usr/share/zoneminder/includes/functions.php 2330
2015-12-23 22:11:28.576290 zmcontrol 18229 FAT Can't connect: No such file or directory zmcontrol.pl
- knight-of-ni
Run the zmcontrol.pl command, with all the parameters shown in the error message you posted, directly on the command line, and see if it produces a more helpful output.
You'll need to be root to do this.
