HDD Full and PurgeWhenFull not working.
rmflagg
Post by rmflagg »
So my hard drive is now full even though I had PurgeWhenFull running, with the percent trigger set at 90%.
I have adjusted the filter so that it triggers when the percent full goes above 80%, but I can execute the filter(greyed out) and if I Submit it to test, I get this error: "SQL-ERR dbFetchAll no result, statement was 'SELECT E.Id,E.MonitorId,M.Name AS MonitorName,M.DefaultScale,E.Name,E.Width,E.Height,E.Cause,E.Notes,E.StartTime,E.Length,E.Frames,E.AlarmFrames,E.TotScore,E.AvgScore,E.MaxScore,E.Archived FROM Monitors AS M INNER JOIN Events AS E on (M.Id = E.MonitorId) WHERE 1 and ( E.Archived = '0' and 100 >= '80' ) ORDER BY E.Id asc limit 0, 250'"
Does anyone know what this means(other than the obvious that there is a problem! :)
rmflagg
Re: HDD Full and PurgeWhenFull not working.
Post by rmflagg »
*BUMP* and another question.
Can anyone help me with deleting entries manually?!? With the HDD full, my system is useless. I wish I knew why the PurgeWhenFull filter didn't work, but that's not as important as getting my system back up and running.
Thanks,
RMFlagg
The easy way is to reinstall the OS and start over.
It looks like you may have a memory issue with MySQL. You can stop zoneminder and delete the images manually with rm but, depending on the size of your hard drive it could take a while. It took me the better part of a day to delete 1.5 TB of images. So, doing a fresh install of Linux may be your best bet. Oh, you did not say which Linux distro you were using and which version of Zoneminder you installed...
bb
