User Security Settings
meadedw
Post by meadedw »
Am looking for a way to restrict the user security settings in events more granular than View / Edit. What I need to do is allow a user to View, Archive, Unarchive specific events but not edit export or delete. The only options I can find are Options > Users > userXYZ > Events the settings are None (Which gives no access what so ever), View (allows user to see events, create video and export but can not select from event screen and all buttons are greyed out), Edit (gives full access)
Problem is security staff should not have the ability to just delete video files on demand, but we do want them to be able to archive a event so that it is not deleted through the clean up script filter
