Warning : Shared data not initialised by capture daemon...
Schuhkasten
Post by Schuhkasten »
after installing 1.28.1 I received follwing Warning in log file for all monitors:
Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor xxxx by zm_monitor.cpp.
Someone knows what can be wrong?
Re: Warning : Shared data not initialised by capture daemon...
Schuhkasten
thx. So assume no solutions yet...
fraser_john
Post by fraser_john »
I only ever get this message immediately after logging in "2016-01-14 12:49:40.858312 zmu 23088 INF Authenticated user 'admin' zm_user.cpp 241"
followed within a second by "2016-01-14 12:49:40.867762 zmu 23088 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor FrontDoor zm_monitor.cpp 426"
Scrolled through a lot of log entries and it is always preceded by a login.
SteveGilvarry
Post by SteveGilvarry »
Schuhkasten wrote:thx. So assume no solutions yet...
If you follow the discussion to github it says a fix was implemented in master to stop the warning in some instances, so 1.29.0 may resolve it for you when released.
