viewing cams on RPI2 running Fedora21
fatcat46
Post by fatcat46 »
I am a NOOB trying to use the Midori browser on my RPI2, that is running Fedora21 and Zoneminder 1.28.1. I cannot view any of the cams. The console comes up but when I select a cam to monitor Midori crashes. I can view all the cams from my windows machine, but not directly on the PI2. I wanted to connect a 24" HDMI monitor to the PI and use it as a security monitor.
Any and all assistance will be appreciated.
FatCat46
Re: viewing cams on RPI2 running Fedora21
You've provided very little information to determine a specific cause, but my guess is you are likely hitting the limits of the hardware.
How many cameras do you have?
What resolution?
What frame rate?
What is the cpu load of the rasp pi2 before attempting to open a live stream and then during?
How much free memory do you have?
Try Firefox instead of Midori.
The Raspberry Pi 2 has about enough processing power to record 1 IP camera at a low frame rate, and then view that camera from a different PC altogether.
Do you have a second Rasp Pi lying around you can use as a web client?
fatcat46
Post by fatcat46 »
Thanks for the reply.
How many cameras do you have? 6
What resolution? 640x480
What frame rate? 30
What is the cpu load of the rasp pi2 before attempting to open a live stream and then during? 1.4x
How much free memory do you have? 60 Pecent
Midori can't handle even one cam.
I installed firefox and it can show all the cams in montage, but as I bring up one at a time side by side the browser crashes. Not enough HP to do what I need to be able to monitor all six at one time. Montage worn' display any side by side. The are all stung out, one above the other in a single vertical column.
I do have another PI I could use as a client. I'll try that
I may also try to redo this on an ODROID. I would like to have one device do it all for me if possible.
Thanks again
FatCat46
fatcat46
Post by fatcat46 »
More info:
I used my ODROID U3 as a web client and was able to get all 6 cams to appear in montage. However, the pictures don't stream. They tend to refresh occasionally. I took some snapshots of the system monitor on each system.
Zoneminder system
zoneminder system
zoneminder system
ODROID web client
ordroid web client
ordroid web client
Is there a way I can improve the performance so I can watch all 6 cameras?
FatCat46
You need to start telling us what your log files show, and not just a couple lines.
Again, make sure you are using Firefox. In addition to insufficient hardware resources, using an incompatible browser will cause this symptom.
fatcat46
Post by fatcat46 »
knnniggett,
Thanks for the response.
I am using firefox. I tried to export the log but it fails with a 500 error. I also do not find a log file on the system. DO I need to do something special to get a log file created?
I was able to copy and past some entries:
Date/Time
Component PID Level Message File Line
2015-12-31 11:00:38.050513 zmc_m6 23296 INF FrontDoor: 16000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:00:37.119837 zmc_m7 8609 INF Shed: 349000 - Capturing at 5.38 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:00:21.281895 zmc_m4 8568 INF SE: 387000 - Capturing at 8.62 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:00:19.290206 zmc_m5 7234 INF GenCam: 422000 - Capturing at 8.62 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:59:47.048512 zmc_m6 23296 INF FrontDoor: 15000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:59:30.621688 zmc_m1 7214 INF bedroom: 469000 - Capturing at 11.63 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:57.967192 zmc_m2 7220 INF PTZ: 420000 - Capturing at 7.04 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:56.158241 zmc_m6 23296 INF FrontDoor: 14000 - Capturing at 18.52 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:51.974479 zmc_m6 23296 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.964243 zmc_m6 23296 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.948589 zmc_m6 23296 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:51.565157 zmc_m2 7220 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.557143 zmc_m5 7234 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.554878 zmc_m2 7220 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.554773 zmc_m1 7214 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.538491 zmc_m2 7220 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:51.534749 zmc_m5 7234 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.534608 zmc_m1 7214 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.518451 zmc_m4 8568 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.513319 zmc_m1 7214 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:51.508461 zmc_m5 7234 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:51.488951 zmc_m4 8568 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.471598 zmc_m7 8609 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:58:51.471243 zmc_m4 8568 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:51.451836 zmc_m7 8609 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:58:51.440840 zmc_m7 8609 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:58:25.866122 zmc_m4 8568 INF SE: 386000 - Capturing at 8.26 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:23.470171 zmc_m5 7234 INF GenCam: 421000 - Capturing at 7.75 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:04.089208 zmc_m1 7214 INF bedroom: 468000 - Capturing at 11.76 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:58:02.716794 zmc_m6 23296 INF FrontDoor: 13000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:57:50.177661 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:57:50.163450 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
here is more:
Date/Time
2015-12-31 11:03:40.679019 zmc_m1 7214 INF bedroom: 472000 - Capturing at 11.90 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:03:36.352513 zmc_m2 7220 INF PTZ: 422000 - Capturing at 7.14 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:03:33.383245 zmc_m7 8609 INF Shed: 350000 - Capturing at 5.68 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:03:11.316684 zmc_m6 23296 INF FrontDoor: 19000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:02:20.196796 zmc_m6 23296 INF FrontDoor: 18000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:02:16.891781 zmc_m1 7214 INF bedroom: 471000 - Capturing at 12.05 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:02:16.093667 zmc_m4 8568 INF SE: 388000 - Capturing at 8.70 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:02:07.748969 zmc_m5 7234 INF GenCam: 423000 - Capturing at 9.26 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:01:29.173358 zmc_m6 23296 INF FrontDoor: 17000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:01:16.814007 zmc_m2 7220 INF PTZ: 421000 - Capturing at 7.19 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 11:00:53.280883 zmc_m1 7214 INF bedroom: 470000 - Capturing at 12.05 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:57:31.133253 zmc_m7 8609 INF Shed: 348000 - Capturing at 5.03 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:57:11.792902 zmc_m6 23296 INF FrontDoor: 12000 - Capturing at 18.87 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:56:54.085807 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:54.076624 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:53.742200 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:53.727937 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:53.483245 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:53.475009 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:53.230527 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:53.221637 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:52.921342 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:52.911898 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:52.719015 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:52.709781 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:52.270254 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:56:52.260411 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:56:51.578307 zmc_m1 7214 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:56:51.561650 zmc_m1 7214 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:56:51.553280 zmc_m4 8568 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:56:51.542035 zmc_m1 7214 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:56:51.540538 zmc_m4 8568 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:56:51.517341 zmc_m4 8568 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:56:51.508481 zmc_m5 7234 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:56:51.496979 zmc_m5 7234 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:56:51.487472 zmc_m5 7234 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:56:51.432668 zmc_m2 7220 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:56:51.422689 zmc_m2 7220 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:56:51.405435 zmc_m2 7220 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:56:51.400833 zmc_m7 8609 WAR Unable to capture image, retrying /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1171
2015-12-31 10:56:51.373177 zmc_m7 8609 ERR Connection dropped by remote end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 999
2015-12-31 10:56:51.363495 zmc_m7 8609 WAR Select timed out /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 157
2015-12-31 10:56:39.156582 zmc_m1 7214 INF bedroom: 467000 - Capturing at 12.05 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:56:35.305400 zmc_m2 7220 INF PTZ: 419000 - Capturing at 7.35 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:56:24.936013 zmc_m4 8568 INF SE: 385000 - Capturing at 8.00 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:56:18.602528 zmc_m6 23296 INF FrontDoor: 11000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:56:14.154479 zmc_m5 7234 INF GenCam: 420000 - Capturing at 7.81 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:55:51.038302 zmc_m6 23296 ERR Unable to decode jpeg /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_remote_camera_http.cpp 1186
2015-12-31 10:55:51.030260 zmc_m6 23296 ERR Invalid JPEG file structure: two SOI markers /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_jpeg.cpp 40
2015-12-31 10:55:27.574072 zmc_m6 23296 INF FrontDoor: 10000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:55:16.437927 zmc_m1 7214 INF bedroom: 466000 - Capturing at 11.90 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-12-31 10:54:36.671267 zmc_m6 23296 INF FrontDoor: 9000 - Capturing at 19.61 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp
FatCat46
Web Console -> Top Right -> Click "Log"
Highlight, copy, then paste
Can't get any easier.
See how none of these are even close to 30fps? That means your rasp pi can't keep up. Drop the frame on all your cameras to 5 or less.
Network error. Are you using WiFi !?!?!?
If you still get these messages after reducing the frame rate, then try a wired connection if you aren't already.
This means your camera is sending images that do not conform to the jpeg standard. This is not always fatal. If you are getting an image, you can ignore these. If it is fatal then change the remote Method from Simple -> Regex. See if that helps.
fatcat46
Post by fatcat46 »
Thanks again for the response knnniggett
I am running everything hard wired.
I cut the FPS to 5 on all cams. and changed to Regex. It seems to help, but the live motion is not adequate to monitor in realtime. Some cams lag a minute or two behind others. I am pretty sure the PI2 is not powerful enough to run zoneminder with 6 cams. I'm wondering if an OROID with 2gb ram would be better.
Any thought?
I would hate to go through the work to find out it is no better.
FatCat46
