Connect Cotier TV-681H2/IP
Camera_Doc
Post by Camera_Doc »
Hi tried to connect a camera (Cotier 681H2 / IP) to ZM. but there is no contact.
Works in VLC "rtsp: //192.168.1.XXX: 554 / Ch01.264? PTYPE = udp"
Debian 8.1
P P "RTSP"
R M "RTP / RTSP"'
What am I doing wrong? :oops:
Logfile:
2015-12-30 14:39:49.789060
zmdc
2503
ERR
'zmc -m 2' exited abnormally, exit status 255
zmdc.pl
2015-12-30 14:39:49.719671
zmc_m2
17809
FAT
No RTSP sources
/tmp/buildd/zoneminder-1.28.1/src/zm_remote_camera_rtsp.cpp
155
2015-12-30 14:39:40.438718
zmc_m2
17811
ERR
Response parse failure, 0 bytes follow
/tmp/buildd/zoneminder-1.28.1/src/zm_rtsp.cpp
86
2015-12-30 14:39:39.682817
zmc_m2
17809
INF
Starting Capture
/tmp/buildd/zoneminder-1.28.1/src/zmc.cpp
195
2015-12-30 14:39:39.128790
zmdc
17809
INF
'zmc -m 2' started at 15/12/30 14:39:39
zmdc.pl
2015-12-30 14:39:39.124420
zmdc
2503
INF
'zmc -m 2' starting at 15/12/30 14:39:39, pid = 17809
zmdc.pl
2015-12-30 14:39:39.084720
zmdc
2503
INF
Starting pending process, zmc -m 2
zmdc.pl
Model
TV-681H2/IP
System structure
Embedded RTOS design (HI3516) , dual-core 32-bit DSP
pure hardware compression, watchdog, 16M FLASH, 128M DDR3
sensor
2 megapixel 1/2.5” CMOS; color 1.0 lux//F1.2; black and white 0.01 lux//F1.2, support day and night switch
Lens
Auto Zoom 6-22mm ,6,8,12,25 3MP Megapixel Lens Optional
Video processing
H.264 video coding; support dual-stream, AVI format ; support adjustable stream 0.1M~6Mpbs
IR distance
4×LED Array, IR distance 80M
Frame Rate
2megapixel 30 frame(full-time) support to adjust 1~30framerate
Video output
main stream:1920×1080,1280×960
sub stream: 640×360,480×270,320×180
Network interface
1*RJ45 Ethernet interface, 10/100M self-adaptation and can resist 6kv static electricity
support the network protocols which is RTSP/FTP/PPPOE/DHCP/DDNS/NTP/UPnP etc
Business functions
Support WEB configuration, real-time video transmission, motion detection and IO alarm linkage end storage, front storage playback/ download
motion detection and IO alarm center remind and screen pop-up linkage, unified client remote monitoring software (UC2) and VM3000 platform etc. system, phone monitoring (Iphone, Android ), through service “through clouds” and provide complete development kit SDK
others
Package Size
GW
Power supply
DC12V/1A
Power
5W
Re: Connect Cotier TV-681H2/IP
Did you try the Source Type Ffmpeg?
If your camera has a user and password you may need to add it to your Source Path
Camera_Doc
Logfile for Ffmpeg:
2015-12-30 15:28:54.110364
zmc_m2
18666
INF
Priming capture from rtsp://192.168.1.89/ch01
/tmp/buildd/zoneminder-1.28.1/src/zm_ffmpeg_camera.cpp
98
2015-12-30 15:28:54.072015
zmc_m2
18666
INF
Starting Capture
195
2015-12-30 15:28:53.866580
zmdc
18416
WAR
Can't find process with command of 'zma -m 2'
zmdc.pl
2015-12-30 15:28:53.366160
zmdc
18666
INF
'zmc -m 2' started at 15/12/30 15:28:53
zmdc.pl
2015-12-30 15:28:53.362980
zmdc
18416
INF
'zmc -m 2' starting at 15/12/30 15:28:53, pid = 18666
zmdc.pl
2015-12-30 15:28:53.070450
zmdc
18416
INF
'zmc -m 2' exited normally
zmdc.pl
2015-12-30 15:28:53.027001
zmc_m2
18626
INF
Terminating Logger
/tmp/buildd/zoneminder-1.28.1/src/zm_logger.cpp
235
2015-12-30 15:28:52.817220
zmc_m2
18626
INF
Got signal 15 (Terminated), exiting
/tmp/buildd/zoneminder-1.28.1/src/zm_signal.cpp
40
2015-12-30 15:28:52.789070
zmdc
18416
INF
'zmc -m 2' stopping at 15/12/30 15:28:52
zmdc.pl
2015-12-30 15:28:52.514400
zmdc
18416
WAR
zmdc.pl
2015-12-30 15:28:49.805036
zmc_m2
18635
ERR
Unable to open input 192.168.1.89/ch01 due to: No such file or directory
264
2015-12-30 15:28:39.768080
zmc_m2
18635
ERR
264
2015-12-30 15:28:29.725155
zmc_m2
18635
ERR
264
2015-12-30 15:28:24.729673
web_php
5957
INF
The system has fallen back to single jpeg mode for streaming. Consider enabling Cambozola or upgrading the client browser.
/usr/share/zoneminder/www/skins/classic/views/watch.php
62
This is the url you have stated works in vlc:
However, this is telling us that you didn't enter the same information into ZoneMinder:
Why did you enter a different rtsp url into ZoneMinder?
Camera_Doc
Both versions work in VLC (PC Windows). Was just that I tried a little different.
Downloaded VLC Android phone, but it does not work in my mobile.
Is there any possibility to get this camera to work with ZM?
Is it compatibel?
Any ONVIF compliant camera should work as long as you know the correct RTSP url.
This likely means you are using Internet Explorer. For best results, use Firefox instead.
Camera_Doc
Ffmpeg or remote?
Camera_Doc
Have got it to work with Ffmpeg.
I had missed that entered RTSP: // before the IP address .
Then it was the wrong search path to see the live stream. Believe it screwed up for me when I tried to get it to work. :D
Thanks for the help
