Connect Cotier TV-681H2/IP
Posted: Wed Dec 30, 2015 1:50 pm
Hi tried to connect a camera (Cotier 681H2 / IP) to ZM. but there is no contact.
Works in VLC "rtsp: //192.168.1.XXX: 554 / Ch01.264? PTYPE = udp"
Debian 8.1
P P "RTSP"
R M "RTP / RTSP"'
What am I doing wrong?
Logfile:
2015-12-30 14:39:49.789060
zmdc
2503
ERR
'zmc -m 2' exited abnormally, exit status 255
zmdc.pl
2015-12-30 14:39:49.719671
zmc_m2
17809
FAT
No RTSP sources
/tmp/buildd/zoneminder-1.28.1/src/zm_remote_camera_rtsp.cpp
155
2015-12-30 14:39:40.438718
zmc_m2
17811
ERR
Response parse failure, 0 bytes follow
/tmp/buildd/zoneminder-1.28.1/src/zm_rtsp.cpp
86
2015-12-30 14:39:39.682817
zmc_m2
17809
INF
Starting Capture
/tmp/buildd/zoneminder-1.28.1/src/zmc.cpp
195
2015-12-30 14:39:39.128790
zmdc
17809
INF
'zmc -m 2' started at 15/12/30 14:39:39
zmdc.pl
2015-12-30 14:39:39.124420
zmdc
2503
INF
'zmc -m 2' starting at 15/12/30 14:39:39, pid = 17809
zmdc.pl
2015-12-30 14:39:39.084720
zmdc
2503
INF
Starting pending process, zmc -m 2
zmdc.pl
Model
TV-681H2/IP
System structure
Embedded RTOS design (HI3516) , dual-core 32-bit DSP
pure hardware compression, watchdog, 16M FLASH, 128M DDR3
sensor
2 megapixel 1/2.5” CMOS; color 1.0 lux//F1.2; black and white 0.01 lux//F1.2, support day and night switch
Lens
Auto Zoom 6-22mm ,6,8,12,25 3MP Megapixel Lens Optional
Video processing
H.264 video coding; support dual-stream, AVI format ; support adjustable stream 0.1M~6Mpbs
IR distance
4×LED Array, IR distance 80M
Frame Rate
2megapixel 30 frame(full-time) support to adjust 1~30framerate
Video output
main stream:1920×1080,1280×960
sub stream: 640×360,480×270,320×180
Network interface
1*RJ45 Ethernet interface, 10/100M self-adaptation and can resist 6kv static electricity
support the network protocols which is RTSP/FTP/PPPOE/DHCP/DDNS/NTP/UPnP etc
Business functions
Support WEB configuration, real-time video transmission, motion detection and IO alarm linkage end storage, front storage playback/ download
motion detection and IO alarm center remind and screen pop-up linkage, unified client remote monitoring software (UC2) and VM3000 platform etc. system, phone monitoring (Iphone, Android ), through service “through clouds” and provide complete development kit SDK
others
Package Size
GW
Power supply
DC12V/1A
Power
5W
Debian 8.1
P P "RTSP"
R M "RTP / RTSP"'
Logfile:
zmdc
2503
ERR
zmdc.pl
zmc_m2
17809
FAT
No RTSP sources
155
zmc_m2
17811
ERR
86
zmc_m2
17809
INF
Starting Capture
195
zmdc
17809
INF
zmdc.pl
zmdc
2503
INF
zmdc.pl
zmdc
2503
INF
zmdc.pl
Model
TV-681H2/IP
System structure
sensor
Lens
Video processing
IR distance
Frame Rate
Video output
Network interface
Business functions
others
Package Size
GW
Power supply
DC12V/1A
Power
5W
