ZM API
Zmjm15
ZM API
Post by Zmjm15 »
Hi guys,
I cannot seem to get the ZM API setup.
I have installed ZM the usual way on 14.04 (https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way)
I am then taking all the stuff from this guide (https://github.com/pliablepixels/zmNinj ... om-Package) that is to install the API bit, but am getting to step 3;
sudo a2enconf zoneminder
ERROR: Conf zoneminder does not exist!
but after following the guides step by step it does not load up the /zm/api for me.
Is there any specific guide that we should be using on 14.04? As my hosting provider doesnt really support ubuntu 15.
Many thanks
Re: ZM API
The API is not part of the 1.28.1 release. You have to install a development snapshot or wait until the 1.29.0 release.
This is the guide you should be following if you want to install a development snapshot:
https://wiki.zoneminder.com/Common_Issu ... PA_version
Zmjm15
Re: ZM API
Post by Zmjm15 »
Ok cool,
Do we know when the .29 is coming out at all?
Many thanks
Re: ZM API
"soon"
Re: ZM API
Actually, I can confidently say "real soon"
Zmjm15
Re: ZM API
Post by Zmjm15 »
i'l be awaiting patiently for this!
thankyou!
AndyNY
Re: ZM API
Post by AndyNY »
I have it in my 1.28.109 release - is that a development release? If so, it works great.
asker
Re: ZM API
Post by asker »
knnnigget pushed 1.29 today!
Please read before posting:
ES docs
zmNinja docs
Pedulla
Re: ZM API
Post by Pedulla »
will a dist-upgrade from the conner ppa do the trick?
BTW, you guys ROCK!
asker
Re: ZM API
Post by asker »
It doesn't look like iconnor has ppas for 1.29 yet. I'm not quite sure when the packages will be released. Let's see what knnniggett says.
ES docs
zmNinja docs
Re: ZM API
Today's 1.29.0 release is just a release candidate. It's still beta.
Rpm's for zmrepo are done. I can't answer any packaging questions about non-RedHat distro's. You need to contact the package maintainer.
Pedulla
Re: ZM API
Post by Pedulla »
:/ I knew that... Ni! Ni! Niiiiiiii!
