just installed - problem getting to run
Danzi
Post by Danzi »
Hello --
today I installed the EASY WAY to Ubuntu 14.04
All seemed to go well. no errors that I noticed.
Got to step 7 of Install process and
How do I-
"startup ZM console in your browser" ?
Step 8 says "open up a browser and go to http://localhost/zm - should bring up ZM"
so I tried
127.0.0.1
PC name
PC IP
no luck....
can any one advise ??
Thanks Dan :shock:
Danzi
Re: just installed - problem getting to run
Post by Danzi »
further info::
and I also tried "localhost"
comes back with-
"Not Found
The requested URL /zm was not found on this server.
Apache/2.4.7 (Ubuntu) Server at localhost Port 80"
Danzi
Post by Danzi »
I tried to redo some install steps- at step 3
ran onto a problem-
dan@ACER:~$ sudo a2enconf zoneminder
ERROR: Conf zoneminder does not exist!
step 4 says "As of Oct 3 2015, zm.conf is not readable by ZM. This is likely a bug and will go away in the next package"
so tried it
dan@ACER:~$ sudo chown www-data:www-data /etc/zm/zm.conf
no help-
however there is one-- (or maybe I'm wrong on this)
dan@ACER:/etc/zm$ ls -l
total 8
-rw-r--r-- 1 root root 211 Feb 17 2015 apache.conf
-rw-r--r-- 1 www-data www-data 1298 Oct 22 13:39 zm.conf
thanks dan
Danzi
Post by Danzi »
now i found this
dan@ACER:/$ sudo ln -s /etc/zm/apache.conf /etc/apache2/conf-available/zoneminder.conf in Ubuntu forum
dan@ACER:/$ sudo a2enconf zoneminder
Enabling conf zoneminder.
To activate the new configuration, you need to run:
service apache2 reload
dan@ACER:/$ service apache2 reload
* Reloading web server apache2
continued with install:
dan@ACER:/$ sudo a2enmod rewrite
Module rewrite already enabled
dan@ACER:/$ sudo a2enmod cgi
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Module cgi already enabled
still no joy!
DAN *
Danzi
Post by Danzi »
i just dont give up!!!
step 7- jumped to restart-
ran "/etc/init.d/zoneminder restart" as SUDO- and success!!!
hope this may help others 1 dan
