Alarm frames getting dropped
Posted: Tue Jan 05, 2016 3:55 pm
Hi everyone,
I have my one-camera setup working pretty well at this point. It does catch motion. It's an Axis IP camera. Physical installation was quite complicated but the result is an awesomely cool peephole in my door that works.
Thanks to the help from this forum, I did fix the issue with it getting stuck in Alarm mode when I opened the door.
Now I'm having a different problem. When it goes into alarm, it drops frames, especially near the end and the beginning. The end is the worst though - it often seems like it skips one or two seconds of alarm frames at the end.
It's running on an older computer (2009) but that computer isn't doing anything other than monitoring this one camera. I have alarm max FPS set around 5. Surely even an older PC can process 5 FPS ?
I've seen other people having similar problems but I couldn't find a FAQ for how to approach this. Any suggestions? I don't want to add any more cameras to my setup until I have a good understanding of how to make it all work smoothly. I do plan to upgrade the computer once I know it's working and also add one or two more cameras. I'm also planning to upgrade to 1.29 as soon as it's out.
