Page 1 of 1
Zoneminder 1.29 and D-Link DCS-2100
Posted: Fri Jan 08, 2016 6:57 pm
by jscmenezes
I am trying to configure a D-Link DCS-2100 with ZoneMinder 1.29 but getting the error:
01/08/16 16:49:37.065074 zmc_m5[5320].ERR-zm_remote_camera_http.cpp/1141 [Unable to get response, disconnecting]
01/08/16 16:49:37.662297 zmc_m5[5320].ERR-zm_remote_camera_http.cpp/1040 [Unable to read content]
The source config is:
USB Cams are OK!
I can't figure out what is wrong!
Any help?
Re: Zoneminder 1.29 and D-Link DCS-2100
Posted: Fri Jan 08, 2016 9:23 pm
by knight-of-ni
From the wiki for the DCS-2100+ :
Did you do that?
Also, make sure your camera is actually sending a grayscale image, since you've told zoneminder it was grayscale.
Posted: Fri Jan 08, 2016 9:32 pm
by knight-of-ni
I used the search tool and found this old thread:
viewtopic.php?t=4523&highlight=2100
Read through all the posts as alternate urls were suggested that might work with your camera.
Posted: Mon Jan 11, 2016 8:22 pm
by jscmenezes
I set up HTTP to 1.0
knnniggett wrote:I used the search tool and found this old thread:
Tried all suggested urls on the post above and didn't work.
The only URL that works is (Firefox, Chrome..):
http://ip/cgi-bin/video.jpg
The conf of camera:
Still not working.. =/
Posted: Tue Jan 12, 2016 1:00 pm
by knight-of-ni
jscmenezes wrote:I set up HTTP to 1.0
But that isn't the same url you are using in your ZoneMinder screenshot.
You should be testing with this url:
http://username:password@ip/cgi-bin/video.jpg
Since this is an mpjeg camera, you can test that url directly in Firefox.
Not all cameras support authentication in the form of user:pwd@host . Are you sure your cameras does?
That would certainly explain why ZoneMinder is saying the camera is not responding.
Suggest you try to get the camera working without any authentication. Once you get it working, then try to figure out if it is possible to enable authentication.
Posted: Tue Jan 12, 2016 6:35 pm
by jscmenezes
If I execute:
$ curl http://user:pass@my.ip.address/cgi-bin/video.jpg > imagem.jpg
I can download a JPG image from the camera like this:
Zoneminder can't read this image from DCS-2100, I guess..
Posted: Tue Jan 12, 2016 7:18 pm
by jscmenezes
There is no way to disable authentication on D-link DCS-2100... =/
Posted: Thu Jan 21, 2016 1:45 pm
by jscmenezes
How can I debug the component zmc_m4 ?
