Server Stopped
marcolino7
Server Stopped
Post by marcolino7 »
Sometime I found my server in Stopped Status.
It's possible to understande why?
Version is v1.28.108
Production Zoneminder 1.31.4 Ubuntu 16.04 LTS on VmWare ESXi
6 Cameras FOSCAM FI8918W
OpenHab Integration
PacoLM
Re: Server Stopped
Post by PacoLM »
Check that MySQL is working. Sounds like a database error.
marcolino7
Re: Server Stopped
Hi PacoML,
I think not, because as soon as I restart ZM from web interface, it start without any action on mysql
OpenHab Integration
marcolino7
Re: Server Stopped
This morning ZM was stopped. Someone can help me? Meanwhile I upgraded to version 1.29.0
OpenHab Integration
SteveGilvarry
Re: Server Stopped
Post by SteveGilvarry »
Logs might have some hints
marcolino7
Re: Server Stopped
Hi Steve,
is the 1st time that I have issue on ZM, so I'm not yet skilled to collect logs.
Where I can find them?
I ckecked /var/log/zm but it's empty. Do you mean logs on web interface?
Regards
OpenHab Integration
marcolino7
Re: Server Stopped
Hi Steve,
I enabled logging on disk. Next time it happen, what logs you need?
Regards
OpenHab Integration
SteveGilvarry
Re: Server Stopped
Any zoneminder specific errors, normally the console has a link to logs using sql logging, which I think is on by default on most packages.
Info on monitoring options http://zoneminder.readthedocs.org/en/st ... gging.html
marcolino7
Re: Server Stopped
today 22 Jannuary 2016 @12:52 zoneminder stopped.
Attached log files, please help me.
Regards
ZoneMInder.zip
Logs files
(101.9 KiB) Downloaded 258 times
OpenHab Integration
Re: Server Stopped
At 12:52 on 1/22/16, ZoneMinder stopped because it could not keep up.
From your zmc_m2.log:
01/22/16 12:52:30.350450 zmc_m2[11766].WAR-zm_monitor.cpp/3097 [Buffer overrun at index 14, image 32814, slow down capture, speed up analysis or increase ring buffer size]
01/22/16 12:52:44.611376 zmc_m2[11766].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
Here are the likely causes:
- You are putting too much of a (camera) load on your hardware.
- You ran a third party application (or scheduled it to run) during that time, which put too much load on the system
- A combination of both
- An intermittent hardware problem, such as a failing disk.
marcolino7
Re: Server Stopped
knnniggett wrote:At 12:52 on 1/22/16, ZoneMinder stopped because it could not keep up.
thanks for help. I'll check in this directions.
Regards
OpenHab Integration
marcolino7
Re: Server Stopped
meanwhile I'll try to find the responsible to this issue, i place a workaround with my monitor server Zabbix. In case all zmc process end, Zabbix alert me with an email and restart zoneminder service.
Thanks again
OpenHab Integration
