I still can not find where to set this basic cctv function.
For example I want to disable the modect from recording on thuesday or ... to only record between 8-18hs.
Is that possible , please say yes ... is the only feature missing so far.
Regards,
Leandro.
How can I define when to record ?
- knight-of-ni
Re: How can I define when to record ?
See the FAQ for the answer to your question:
http://zoneminder.readthedocs.org/en/la ... ay-or-week
Create different States and then create crontab entries to activate those states when you want.
Hi , thanks for the response.
Although it could work, I think it is a littel difficult for a regular user.
It is a shame ... having an easy configurable scheduller, ZM would be the best cctv software ever.
Do you think , developers will add this feature ?
Thanks,
Leandro.
Thanks,
Leandro.
- knight-of-ni
I'm sorry you have difficulty understanding, but the feature I pointed you to is designed to do exactly what you asked.
Please helpme understand.
What I can check so far is that when you go from running to stop state, monitors are not longer accesible, so modect will stop recording but I can not look at the monitors either.
Please give me a clue here...
You say is it possible to change the individual function of a monitor in a crontab line with the zmpkg.pl script ?
How to do it ? lets suppose I want:
monitor1 to goes from monitor to modect on weekdays from 2 to 4 am.
Monitor2 be allways in monitor mode.
Monitor3 be allways modetc mode.
Is that possible ?
Please point some doc if you are tired to explain to idiots like me.
Regards.
Is that possible ?
Regards.
So reading the doco linked I am pretty sure this is what you need to do. Never done it myself.
Set
Monitor 1 to Monitor
Monitor 2 to Monitor
Monitor 3 to Modect
Click on the Running/Stopped link at top of console.
Enter name for new state into text box. For example "Daytime" then click save. You should now have an extra choice in the dropdown box for the state.
Now set
Monitor 1 to Modect
Monitor 3 to Modect
Now click Running/Stopped again and create a new state, say "Nighttime"
Ok so now you have the two desired states with the monitors running in the desired mode. Each different setting you want for a camera means saving a new state as it holds the mode of all cameras at once. I think this is where you are going wrong as you are thinking you want to just change each camera, but instead you save all the cameras to a state.
Now use cron to control the changing of state, not the individual monitors. Google cron if you are not sure what this is doing.
crontab -e
Set
Monitor 3 to Modect
Now set
Monitor 1 to Modect
Monitor 3 to Modect
crontab -e
0 2 * * 1-5 root /usr/local/bin/zmpkg.pl Nighttime
0 4 * * 1-5 root /usr/local/bin/zmpkg.pl Daytime
Thanks Steve !! I got it now.
