Page 1 of 1
Disable deep storage?
Posted: Sat Jan 16, 2016 11:07 am
by ET328
My 1.28 installation has deep storage disabled. How do I upgrade to 1.29 and keep the old setting and events?
Re: Disable deep storage?
Posted: Sat Jan 16, 2016 4:06 pm
by bbunge
When you upgrade to 1.29 your settings should not change. However, 1.29 is still in testing and I would not upgrade your current system unless you are prepared for some things that may not work. You may be best to wait a bit for the official release.
With that said it is always a good idea to back up your database before a change.
bb
Posted: Sat Jan 16, 2016 10:43 pm
by knight-of-ni
You have to use deep storage
-stop zoneminder
-backup your dB and events
-enable deep storage under options
-turn on deep storage under options
-run zmupdate.pl --migrate-events as root
-upgrade zoneminder to new version only if previous steps succeed
Posted: Sun Jan 17, 2016 6:49 am
by ET328
Only problem (for me) is, that using deep storage causes a directory monitor program (Autohotkey script) to fail to notice changes. I'm using it to popup a desktop notice when an alarm occurs i.e. a new directory is created. Haven't figured out another way to do it. There probably is...
Posted: Sun Jan 17, 2016 9:49 am
by asker
ET328 wrote:Only problem (for me) is, that using deep storage causes a directory monitor program (Autohotkey script) to fail to notice changes. I'm using it to popup a desktop notice when an alarm occurs i.e. a new directory is created. Haven't figured out another way to do it. There probably is...
Yep there is another way. Google for zmeventserver.
Another user has used it exactly for what you are doing and posted it in the user contributions section.
