Debian 8.2 installation
sevelen
Post by sevelen »
I´m try to install zoneminder on a Debian 8.2 system with the apt-install zoneminder command. I add allready the source.
During the installation I getting a strange error to me.
Preparation for unpacking.../zoneminder_1.28.1-6~bpo8+1_amd64.deb ...
unpack of zoneminder (1.28.1-6~bpo8+1) ...
dpkg: Error processing the archive /var/cache/apt/archives/zoneminder_1.28.1-6~bpo8+1_amd64.deb (--unpack):
 Try, »/usr/share/perl5/ZoneMinder/ConfigAdmin.pm« to overrwrite, wich is in package libzoneminder-perl 1.28.0+nmu1 ist
Can anybody help me please. I´ve no more idea at the moment
Thank you so much.
Re: Debian 8.2 installation
You've got a package conflict.
It looks like the version of zoneminder you've already got on your system is "1.28.0+nmu1" and the version you are trying to install is "1.28.1-6~bpo8".
Because the suffixes are different, your system sees two completely different, unrelated packages, rather than a newer version of the same package.
Consequently, the package manager is (correctly) refusing to install the new version because it would overwrite files you've already got on your filesystem.
The most straightforward approach here would be to be to uninstall zoneminder 1.28.0 completely, and then install zoneminder 1.28.1.
Make sure and backup anything you don't want to get deleted during this process.
sevelen
Post by sevelen »
YOU MADE MY DAY
Not sure what i doing wrong before I try a lot to install and deinstall. But now after remove and pure and clear as well it work.
Thanks so much.
All this shit happend after dist update to 8.2
sevelen
Post by sevelen »
Ok next strange or I´m strange,
I was not getting a camera picture before so I install apt-get install FFMPEG
During that it remove zoneminder?
Is there a need to extra install FFMPEG?
robertbruce
Post by robertbruce »
very similar thing happened to me when i used apt-get and manually edited sources.list from a su console on the desktop....i got the extra backports boot option
in the same enviorment i used synaptic instead and it flew thru from a fresh install...
Satellite L20, 8G flash 512-2G Ram
Ubuntu Server 10.04 32 bit
ZM 1.24 Running 2 USB cams at 16FPS
Intel P4, 40G IDE, 1G Ram
Ubuntu Server 12.04 64 bit
ZM 1.25 Running 6 USB cams at 10FPS & 1 Sony IR CCTV Cam 420lines at 10FPS
